Does this manifold need relief cuts?
Old Aug 23, 2005 | 07:06 PM
Snail Tuning's Avatar
Default Does this manifold need relief cuts?
ok so ive never made a manifold before. and i bought this one half way finished. I just added the flange. does the head flange need relief cuts to aid in flexing or will it be fine the way it is? also im going to make a brace from the block to the turbo sense the turbo hangs out so far.
thanks
Modified by Snail Tuning at 11:30 PM 8/23/2005
Old Aug 23, 2005 | 07:35 PM
own6volvos's Avatar
Not worth it.. barely any runner length to deal with.
Old Aug 23, 2005 | 08:56 PM
ineedhelp's Avatar
Default Re: (own6volvos)
are relief cuts really necessary, for manifold with longer runners.
Old Aug 23, 2005 | 09:49 PM
ExploitedRacing-HR's Avatar
Acually i have found that i DO need relief cuts with log manifolds but not with tubular manifolds. The reason for this is because the flange expands and pulls the T's and 90's with it.... on a tubular manifold the flange can expand but then the long tubes have some flex to them with heat allowing them to not crack.
Old Aug 24, 2005 | 09:09 AM
Default Re: (ExploitedRacing)
id rather have them and they not need them then to have something crack. so where on this manifold should i put the reliefe cuts?
Old Aug 24, 2005 | 09:31 AM
snoochtodanooch's Avatar
Default Re: Does this manifold need relief cuts? (Snail Tuning)
i like the exhaust piping step out on the compressor side. I have the same thing as a ghetto rig for my edelbrock kit, connecting off the outlet to a rubber elbow. Rubber elbows don't break as often as cast aluminum ones do.
Old Aug 24, 2005 | 10:50 AM
Default Re: Does this manifold need relief cuts? (snoochtodanooch)
were ganna put a mushroom style airfilter where the powersteering resivor usualy is, but sense this car doesn;t have pwrsteering it will fit and i can make a shield and have a cheap cai and no water will ever get sucked up cause its almost as high as the valve cover.
where would you guys put in felief cuts at? i midaswell add some while its off the car sense it only takes like 5 mins to do with a cutting disc and angle grinder.
400WHPITR
Jan 15, 2007 02:24 PM
metal craft
Welding / Fabrication
32
Aug 23, 2006 12:24 PM
lkailburn
Jul 31, 2005 11:57 AM
W.Zero
Mar 2, 2003 09:48 PM
