SI cluster in DX civic???????????
Old Aug 23, 2005 | 06:20 PM
BOOSTEDwhiteEK9's Avatar
Default SI cluster in DX civic???????????
I put a '99 civic si cluster in my '99 civic dx and everything works except for the tachometer. can anyone help me out???
Old Aug 23, 2005 | 06:39 PM
JDMFreak's Avatar
Default Re: SI cluster in DX civic??????????? (BOOSTEDwhiteEK9)
bad cluster? it should work right away.
Old Aug 24, 2005 | 07:05 AM
Evil-EK's Avatar
Default Re: SI cluster in DX civic??????????? (JDMFreak)
check to make sure the plug on the back of the cluster is tight. If it has any play then it is not making a good connection. That cluster will plug in and work without modification in any 96-00 civic.
Old Aug 24, 2005 | 08:33 AM
Audi RS4's Avatar
Lover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak &raquo;</TD></TR><TR><TD CLASS="quote">bad cluster? it should work right away.</TD></TR></TABLE>
Second that!!
Old Aug 24, 2005 | 03:52 PM
even if the shop put a different engine harness. I got a B20B in my civic but I think they used a an LS harness dose thst matter.
Old Aug 24, 2005 | 04:01 PM
Evil-EK's Avatar
Default Re: (BOOSTEDwhiteEK9)
should not matter. The harness you are pluging your cluster up to is the dash harness and they had no business changing that out. I cant see why they would have used the ls harness when all they needed to do was extend a couple of plugs on the factory engine harness and plug it up. Are you still obd2?
Civ-dx-96
11
Mar 27, 2013 05:20 PM
ServiceAdvisor
Feb 6, 2007 08:16 AM
kazenokoe
Apr 10, 2005 04:52 PM
Optik
Nov 13, 2004 07:07 AM
