hydro to cable tranny internals
Old Aug 23, 2005 | 06:15 PM
ali_232's Avatar
Default hydro to cable tranny internals
i have a prefectly good cable and a hydro trannys sitting around and i need to use a hydro tranny expt the hydro has its fifth gear is burnt. my qestion is, is it possible to swap the interanls between the trannys.
the hydro tranny is a out of a b16a2
the cable tranny is y1 tranny (jdm sir tranny)
Old Apr 8, 2007 | 11:19 AM
rudebwoy's Avatar
Default Re: hydro to cable tranny internals (ali_232)
I am in need of the answer to this question also. very important.
please dont tell me to buy a hydro tranny
I have a screwed b16 hydro tranny, and a working 92 ls cable tranny.
just want to know if it will work
Old Apr 8, 2007 | 12:22 PM
NJIN BUILDR's Avatar
Default Re: hydro to cable tranny internals (rudebwoy)
I believe the 92 ls is a large imput shaft tranny and those internals should fit in the b16a2 cases.The OP is out of luck with the y1/a2 swap.The y1 is a small shaft I think and won't work in the b16a2 cases.
Old Apr 8, 2007 | 10:00 PM
soulpwr's Avatar
Default Re: hydro to cable tranny internals (NJIN BUILDR)
Put simply. If the main shaft is the same (number of splines) the internals are interchangeable.
Old Apr 8, 2007 | 11:03 PM
rudebwoy's Avatar
sweet, short and simple. thanks!
Walterronny
May 27, 2006 04:12 PM
89 CRX SI
Mar 28, 2004 06:21 AM
jdmCivic925
Sep 23, 2003 10:02 PM
