Process For Replacing the Crankshaft Pulley
Old Aug 23, 2005 | 05:37 PM
H22LudeLover's Avatar
Default Process For Replacing the Crankshaft Pulley
Can anyone explain to me how to replace the Crankshaft Pulley for my 93 Si Lude?
Old Aug 23, 2005 | 07:36 PM
LudeyKrus's Avatar
Jack up the car and replace the Driver's side wheel.
Detension and remove the alternator, power steering, and a/c belts if you have them.
Remove the big bolt in the driver side fender well holding the crank pulley on. I believe it's a 19mm, but it's different on some motors. The BEST way to get it off is to use an impact gun. You could use a bigass breaker bar if necessary. You may have to keep the motor from turning; one way to do this is to put the car in gear and have someone press the brakes hard while hitting the breaking bar.
Remove pulley and install new pulley in the opposite order.
nocturnaldragon
54
Aug 31, 2014 03:49 PM
Tommy_Gunns
May 8, 2013 10:18 AM
natebaur
May 9, 2009 05:09 PM
grngsr01
Oct 23, 2005 05:47 AM
originalbadbob
17
May 27, 2004 12:34 PM
