rear sway bar position
Old Aug 23, 2005 | 04:27 PM
slthatch's Avatar
Default rear sway bar position
please post pics of how the sway bar is positioned on a hatch having trouble with the install
Old Aug 23, 2005 | 05:28 PM
pdiggitydogg's Avatar
Old Aug 23, 2005 | 05:52 PM
dohcMONSTER's Avatar
Default Re: (pdiggitydogg)
bling blang bloow!
Old Aug 23, 2005 | 06:23 PM
upgraded's Avatar
you need to make sure you have the suspension loaded, or as it would be if the car were on the ground. The endlinks will not line up as they should otherwise if thats where you are having your problem. Hope that helps.
Old Aug 23, 2005 | 07:19 PM
Rhythm's Avatar
Here's one... I just put this GSR sway on last week. You're gonna love the difference.
Old Aug 23, 2005 | 07:47 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: rear sway bar position (slthatch)
what exactly do u need to see? I have two pics, one from far, one close up, hope this helps.
Old Aug 23, 2005 | 07:50 PM
Hatch It's Avatar
Default Re: rear sway bar position (rukawa1one)
mmmmm sway bars.....like he said....your going to love it
BTW nice set-ups
Old Aug 23, 2005 | 08:10 PM
jboy08's Avatar
Default Re: rear sway bar position (Hatch It)
Old Aug 23, 2005 | 08:31 PM
TrackSol's Avatar
jboy:
That's a unique way of mounting a the sway bar to the LCA; I've never seen that before.
Old Aug 23, 2005 | 08:39 PM
jboy08's Avatar
Default Re: (TrackSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrackSol &raquo;</TD></TR><TR><TD CLASS="quote">jboy:
That's a unique way of mounting a the sway bar to the LCA; I've never seen that before. </TD></TR></TABLE>
suspension techniques rear sway bar/tie bar combo
Mark D. Surface's Avatar
To those that have installed or upgraded their rear sway bar have you guys/gals noticed the difference in steering? i.e....understeer/oversteer? TIA!
Old Aug 23, 2005 | 09:27 PM
iaredavid's Avatar
Default Re: (Mark D. Surface)
it depends on the overall balance of your suspension. short answer: you get closer to oversteer.
long answer: the simple factors that cause a difference are your spring rates, front sway, and rear sway. stiffer spring rates will allow oversteer to come more easily. having just a rear sway will usually cause oversteer. having a factory spec front and rear sway will cause neutral to understeer. having an oversized rear sway with a factory spec front sway will lean toward oversteer. there are many other factors, but in short, more toward oversteer with a bigger rear sway, or by simply having a rear sway. if you dont have a front sway, be careful in the rain.
Old Aug 24, 2005 | 07:14 AM
slthatch's Avatar
thanks for all the help guys yesterday i put my skunk 2 lower tie bar on along with my spc LCAs and my car feels alittle squirley right now with just the tie bar on (much like a firetruck with four wheel steering) But today i will be putting on a stock gsr rear sway bar and a stock civic front sway hopefully with the sway bars it will compensate for the tie bar and it wont be as squirley
Old Aug 25, 2005 | 09:22 AM
slthatch's Avatar
still havent put my front sway on it but i think my front suspension is too soft, i'm running tokico blues with some coilovers, and my suspension is still really squirley any other ideas?
Old Aug 25, 2005 | 09:46 AM
DC4_MADMAN's Avatar
Default Re: (slthatch)
I dont have my rear sway in yet, waiting for my adj endlinks to come, but I want to play the show off game too, a bit dirty but oh well-
Old Aug 25, 2005 | 10:09 AM
EK k kay's Avatar
Default Re: (4door_demon)
^Boo no sway bar
What kind of LCA's are those? They don't look very safe.
Old Aug 25, 2005 | 10:12 AM
DC4_MADMAN's Avatar
Default Re: (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">^Boo no sway bar
What kind of LCA's are those? They don't look very safe.</TD></TR></TABLE>
23mm ITR waiting to go in.
Function 7 and they are about 2" thick, I am not worried at all about breakage.
Old Aug 25, 2005 | 10:50 AM
gftgrill's Avatar
Default Re: (jboy08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jboy08 &raquo;</TD></TR><TR><TD CLASS="quote">
suspension techniques rear sway bar/tie bar combo</TD></TR></TABLE>
I love mine, although the endlinks bolted onto my rear arms.
Old Aug 25, 2005 | 10:29 PM
Toxidomask's Avatar
Default Re: (gftgrill)
NO sway bars but with ASR's?? hehehe yey for Charleston!! whats up man.
Old Aug 25, 2005 | 10:50 PM
midwesta's Avatar
damn some **** i havent even seen before in here. baller. i need to make something like that.
Old Aug 26, 2005 | 10:34 AM
CivicSol's Avatar
Default Re: my set up
right know its the same 23mm ITR rear bar with ITR LCA's but I installed tokico illumina shocks and it looks a lot cleaner LOL
for more info go to http://my.prostreetonline.com/member/civicsol/
Old Aug 27, 2005 | 04:18 AM
Toxidomask's Avatar
Default Re: my set up (CivicSol)
that is clean, what kind of brace are you using? is that for the SI? didnt know 23mm d brackets would bolt on to that.
Old Aug 27, 2005 | 07:21 AM
CivicSol's Avatar
Default Re: my set up (Toxidomask)
they are from my girlfriend's acura. so the're OEM. dont remember form which
Old Aug 27, 2005 | 07:27 AM
Sleepy_Red_hatch's Avatar
whats all this about the sub-frame being ripped apart by sway bars?
Old Sep 2, 2005 | 09:50 PM
racin_fool's Avatar
Default Re: my set up (Sleepy_Red_hatch)
Alright, I guess I havent looked well or long enough just yet at the rear of the car, but will my 99 ek hb have the proper mounting locations for the rear sway brackets or what will i need to bolt these on? I already have the rear brake setup from a 99gsr minus the lca's. It just appears that in these pictures posted above, there are some extra brackets or something bolted on holding the sway D-brackets in place. (obviously still new to all of this).
Here's another quick question.. for the rear brake conversion I did recieve the rear lca's from the gsr. Now, will those bolt up just the same as what is already on my car or will I need to get the rear shocks and such from that vehicle? I'm sure it would bolt to the spindle and lower subframe the same, just not sure about the lower shock mounting position.
Just FYI its all from a 99 gsr going onto my 99 ek hatch
One final thing, what kind of rear LCA do you recommend if the gsr stock lca will not work for me? Apparently people have some bad opinions about the Omni-power stuff..
Modified by racin_fool at 11:16 PM 9/2/2005
