WTB b-series t3 manifold downpipe combo
Okay i'm picky if you don't have this then don't reply!
I want a complete manifold (any type considered but must have external tial 38mm wg flange)
and a 2.5 or 3 inch downpipe that will fit. down pipe should be PASSANGER SIDE ONLY! and must allow for use of a thick 1/2 radiator with oem shroud.
I don't have ac or ps and would rather not notch the block or whatever.
this needs to fit my lsvtec swap in my 93 civic coupe okay thanks have at it.
NOTHING CRACKED OR NEEDING REPAIR EVER!!!
Wastegate dump tube is a plus! BEST would be wg dump into downpipe.
Doesn't have to be pretty
has to be less than $700
gotta fit perfect and be easy to install/work with
acy76
Jan 26, 2006 04:58 AM
