smog check help.. failed :(
95 honda delsol si.. 142k miles.. recently did tune up ( adjusted timing, spark plugs, rotor and cap, oil change, pvc valve )
took it to the smoke check station today and failed..
any ideas what it could be? i know there can be tons but what could i do myself to bring those numbers down...
since it was a only test station the guy couldnt find out what it was.. but he mentioned that it could be the o2 sensor. UPDATE ... i dont get an o2 code.. i get code 43...but thats only when im coasting on the freeway about 55 m/h in 4rth gear( turns off if i turn off the car and then start it up again and it wont come up on till again i get on the freeway and coast at the speed mentioned)
UPDATE .. i reset the ecu (by taking out the fuse for a couple o fminutes) and so far (5 tmies on the freeway) no cell so far.. any ideas why??
any ideas would be apreciated...
Modified by JCracer723 at 7:44 PM 8/26/2005
Modified by JCracer723 at 7:45 PM 8/26/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 »</TD></TR><TR><TD CLASS="quote"> i do get an engine check code o2 sensor but thats only when im coasting on the freeway about 55 m/h in 4rth gear( turns off if i turn off the car and then start it up again and it wont come up on till again i get on the freeway and coast at the speed mentioned)
There's your problem. Doesn't matter if the code goes away, the fact that it keeps coming back should be a sign. Get a new one!
a bosh one would do the job?
any ideas why it only comes on when im coastin on the freeway at that speed??.. because if i dont get at that speed at all the code wont come on..
Modified by JCracer723 at 11:42 PM 8/23/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 »</TD></TR><TR><TD CLASS="quote">a bosh one would do the job?
... ...</TD></TR></TABLE>
Yes, I passed smog with a bosch $12 deal and a 12 year old cat. Looked like a fine sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1z1c »</TD></TR><TR><TD CLASS="quote">Yes, I passed smog with a bosch $12 deal and a 12 year old cat. Looked like a fine sensor.</TD></TR></TABLE>
lord where the hell did u get urs.. ive been calling around and they are about 60 bux each..
in the other hand.. i was hauling *** town and freeway today and guess what.. no check engine light.. i did it cuz i wanted to check the code ( last time i checked it was like 5 months ago ) so i wanted to make sure it was still o2 sensor code..
could a new cat help to??
A cat would help only if your cat wasn't working properly as in it was clogged, has holes in it, or you somehow burned the damn thing because just 1 spark plug didn't work. lol. raw fuel dumped into the cat = burn and destruction.
i think the o2 sensor would help. why not just listen to the engine? if it says it was wrong before why wouldn't it be wrong now. clearly theres something wrong with it? well good luck buddy. latez.
updated (see first post).. i checked the code. and it wasnt none of the 2 o2 sensor codes... it was code 43.. but i reset the ecu and no cells so far
Get a fuel pressure regulator. I spent hundreds of dollars on a cat and other stuff last year and failed miserably still. I got a fuel pressure regulator and have no problems now. When you go to smog, turn it down, and then when you leave, just turn it back up. it works every time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HatchB16 »</TD></TR><TR><TD CLASS="quote">Get a fuel pressure regulator. I spent hundreds of dollars on a cat and other stuff last year and failed miserably still. I got a fuel pressure regulator and have no problems now. When you go to smog, turn it down, and then when you leave, just turn it back up. it works every time
what brand did u get? and how low did u turn it down?
</TD></TR></TABLE>what brand did u get? and how low did u turn it down?
I have an AEM regulator with a B&M guage. Stock is supposed to sit at 41, but for emissions, you can turn it down to about 20 and still have it idol to be tested. just don't smash on the gas while you have it turned down. It will not go anywhere. I hope that helps
it regulates the amount of fuel pressure going to the engine. I used to fail the Hydrocarbons, among other things, by about 400 (really bad) and I got it to pass the first try with the regulator. I am not the only one who uses this. Everyone else i know has done the same thing and was able to pass.
Just screw the cat...i spent all kinds of money on a new one and still failed. The fule pressure regulator will dot he job, trust me. We have been fighting with emissions here for years, and it is just so much easier to get the regulator.
soMedic
Jul 27, 2006 08:08 AM
vega_ROCKS
Jun 25, 2005 01:12 AM
itrhopeful
29
Jan 16, 2005 03:54 PM
