Rear Disc Swap..yet braking power feels the same. What Prop Valve, Master Cylinder???
Old Aug 23, 2005 | 02:01 PM
Bryro22's Avatar
Default Rear Disc Swap..yet braking power feels the same. What Prop Valve, Master Cylinder???
I did a rear disc conversion on my 95 Del Sol. I just slapped on the whole rear suspension from a 94 integra ls. My braking performance still sucks so I am going to put in a 40/40 proportioning valve but i dont know which one i should use for the Del. EK, EG, DC...and what year?
And about the master cylinder and booster...what are you guys typically using when doing a rear disc conversion? Is buying a MC/booster a "must" when changing out a proportioning valve or will the PV be compatible with my current Master Cylinder/booster combo?
Thanks.
Old Aug 23, 2005 | 02:07 PM
SirRevvs's Avatar
Default Re: Rear Disc Swap..yet braking power feels the same. What Prop Valve, Master Cylinder??? (Bryro22)
https://honda-tech.com/zerothread?id=364783
Try this, it was about 5 threads down from yours
fryman
Aug 7, 2015 06:49 PM
egCoupe
Suspension & Brakes
Oct 9, 2009 08:10 PM
blackccoupe
Sep 14, 2003 07:23 PM
AGS
Jul 2, 2003 11:48 PM
