gauges??
Old Aug 23, 2005 | 12:31 PM
jimmy92civic's Avatar
Default crazy gauges??
i have a 92 civic dx and the temp gauge is all the way up as soon as i start it. and the speedo needle is on the wrong side if the pin (reads below zero) and when i get on the highway it goes backward to about 100mph
Modified by jimmy92civic at 3:49 PM 8/23/2005
Old Aug 23, 2005 | 12:45 PM
nub.96ek's Avatar
Default Re: gauges?? (jimmy92civic)
Sounds like either someone that owned it before you messed with the cluster and moved the needles [they will spin on the pin mount if you push them hard enough], or you have a SERIOUS wiring problem!
Old Aug 23, 2005 | 12:46 PM
nub.96ek's Avatar
Is the temp needle on "C" when the car is off, or is it "up" a little?
JDM-97CX's Avatar
Default Re: gauges?? (nub.96ek)
Some one has been messing with things, alot of things. It almost sounds like they are running power through the ground side and ground through the power side.
Old Aug 23, 2005 | 01:03 PM
the speedo works sometimes when i get off the highway, then when i turn the car off it doesn't work again the jumps to 100 then below the pin again and the temp gauge is reading c before i start it
86RedFoxBodyGT
Nov 6, 2010 06:46 PM
97grnrs
Feb 17, 2007 07:06 AM
daidilus
Sep 5, 2006 08:47 PM
BIG RICH
Jul 13, 2004 10:39 PM
DJ:A
Dec 18, 2001 06:23 AM
