LARGEST for sale list ever! B-series, D-series, CARS, always updated!!!!
Old Aug 23, 2005 | 12:21 PM
Tuan's Avatar
Default LARGEST for sale list ever! B-series, D-series, CARS, always updated!!!!
last updated 3/31/2006
- 88 to 93 Acura Integra tokico blue shocks. In great condition, $200
- 88 to 93 Acura Integra LS cable tranny, slightly grinds into 1st, $300
- Acura Integra LS OBD1 engine harness
- 99 GSR swirlies, only a pair, scratched up.
- A pair of 15” Falken Azenis tires, 85% tread.
<U>CARS & SHELLS </U>
1994 Acura Integra LS, rolling Shell, Just installed a B18a swap in it. with a B18B head, GSR tranny, painted championship white,(originally black) tan interior, comes with doors, rear hatch, suspension, dash, steering wheel, shaved moldings, climate controls, carpet, door panels, rear panels, gauge cluster. 98 rear lights. steering wheel,
**NO: center console, armrest, seats, airbags, and the exterior, NO front end! only has a ITR radiator support on it. What needs to be done: ECU wiring, CLEAN TITLE! Registered til September 2006!
link to thread: http://hondamarketplace.com/zerothread?id=1519855
1999 Toyota Tacoma xtra Cab V6, low milage, 45K miles on it, Champagne, bed liner, new tires, new brakes & Rotors, Beige int., AC, PS, tow hitch (never used). $10,500
<U>SWAPS & Motors</U>
- B18a1, LS long block w/ intake manifold, alternator. TB,
- B18a1, LS short block, don’t know if spun rod or bad rings
- B18a1, LS complete head
- B18a1, LS short block, needs new rings
- LS partial motor swap: B18a1 short block w/ B18b head, complete swap, GSR tranny, shift linkage, axles, P75 OBD1 ECU, rear mount, top tranny mount, driverside mount, alternator, distributor, starter, flywheel, clutch, $1,500
- 1995 Acura Integra B-series GSR Hydro Tranny, no grinds, 70K on it,$500 firm
- B16a1 JDM 1st gen, complete bottom end, no knock sensor, unassembled
<U>AFTERMARKET</U>
- Vortech FPR - red
- 88-91 CRX CARCOVER! Very nice., $30
- P2P OBD2a 1996 and up Honda Civic EX ecu
- P2P Automatic ECU Honda Civic EX OBD2 2000
- 8 lbs Clutch masters aluminum flywheel - b-series. $50 - needs resurfacing
- RAZO - RED, Carbon fiber shift ****
- TRUST front polished strut bar , 88-91 CRX & Civic
- DC Sports strut bar, for 94 and up Integra and 92 and up Honda Civic's
- Type R front sways bars & GSR rear sway, comes with end links, $100
- AEM Cams Sprockets B-series - Red, $100
- Autometer Phantom Air fuel ratio gauge, white face, black ring
- Autometer Phantom Fuel pressure gauge, white face, black ring - no sending unit
- Autometer dual gauge pod black for 92-95 Honda Civic
- STR yellow/goldish dipstick
- Hood pins, silver polish new.
- Blue Oil Cap aftermarket
- RAZO shift ****, carbon fiber x 2, ONE THREADED, ONE NOT
- LS shift ****, - really dirty
- 16" Rota GT3 center caps, polished.
- Rear tokico Shocks, less than 5K, EG or DC
- 92 and up Honda Civic hatchback, HONDA Floor mats, don't know if it's the same with coupes, $40
<U> ACURA INTEGRA, B-series parts</U>
- 94 Integra power steering rack, lines, pump, rings, line coolers, bottle. etc.
- 94 Integra COMPLETE ABS Systems, computer, all brakes lines, sensors, etc.- only trade for an RS non-ABS parts. – TRADE only
- 94 Integra windshield fluid resevior
- 94 and up Integra wiper arms
- 94 Integra, cruise control modules, computer, lines, cables, even button
- Integra Windshield wiper arms
- 1994 and up, Integra radiator reservoir
- 1994 and up Integra Hood latch & lines
- 2001 Acura Used alarm w/ harness, easy plug and play -(keyless entry)
99 Integra stock CD head unit, doesn't play CD's - good for radio have the code
94 and up, Integra Rear window interior panels - silver
94 and up, Tan Acura Integra interior, carpet, door, panes, rear panels, dash,$150
94 and up, Integra right hand drive BLACK carpet,
94 and up, Integra stock springs
94 and up, Integra AC condenser, compressor
94 and up, Integra stock side skirts – stock red
94 and up, GSR intake ARM w/ filter
94 and up, LS crank Pulley, non-obd & obd1
94 and up, Integra Cruise control module & pedal cable & module.
94 and up, Integra rear window moldings
89 - 93, Integra Upper A-arms
94 and up, JDM integra rear trunk brake light, has INTEGRA in green
- B-series Top mount
- B-series Driver side post mount & bracket
PR3 intake manifold w/ fuel rail
PR3 crank pulley, w/ V-belt ring
B-series OBD1 alternator, $80
B16a stock cams w/ cam gears
B16a2 2000 USDM Crank, less than 8K miles.
B16a2 girdle
B16a2 dump tube
B16a2 rear coolant water pipe
B18A/B, Acura Integra LS cam caps
B18A, LS head
B18B, Acura Integra LS intake manifold w/ fuel rail.
B18a1, post mount x 3 & bracket
B-series Cranks angle sensor w/ sprocket
B-series oil pan, LS & B16a
B-series VTEC valve cover $40 - condition 7/10 needs repaint
B-series plug wire cover - spray painted black
B-series top tranny mount x 4
B-series injectors, NON-OBD, OBD2
B-series flywheel stock x 4
B-series alternator mount x 3
B-series crankshaft pulley, LS
B-series tensioner, x 4
B-series plug wires, lots of used sets,
B-series power steering mounts. P72
B-series AC compressor
B-series stock exhaust manifold top half only
B-series pilot bearing, Cable, new in box
B-series main caps
B-series Oil sump
B-series head studs, I don't know which is which
<U> HONDA CIVIC, D- series parts</U>
2001 Honda Civic Stock CD player, with code
96 CX VTEC head
2000 Honda Civic EX coupe, stock piping, $60
96 & up Civic Aluminum Oil pan, black & silver x 2
92-95 Honda Civic Cruise control module - with cables x 3
92-95 Honda Civic stock springs
92-95 Honda Civic mud flaps, give me an offer! don't know if it's for coupe or HB
94-95 Honda Civic - Condensor
D-series 92-95 driver side mount
D-series 92-95 top tranny mount
D-series 92-95 front tranny mount
D-series 92-95 rear tranny mount
D-series Alternator OBD1 & OBD2 x 8
D-series Crank pully & pin
D-series alternator mounts
D-series Fuel rail
D-series throttle bodies, all missing TPS's
D-series Injectors, obd 1 & 2's
D-series shift linkages for 88-91 & 94 and up.
D-series starters, Si, DX, etc
D-series Intake manifolds, Si & DX x 6
D-series flywheel x 5
D-series valve covers, VTEC 96 and up
D-series valve cover, NON-VTEC
D-series thermostat housing
D-series plug wires
D-series head studs
<U>MISC – bolts and etc.</U>
Any bolt on a Honda or Acura, tranny bolts, mounts, 10mm,12, 14, 17, 19
Plugs for every part of the car, except ECU & distributor & lights
IAT sensor x 4
IAC valves x 3 only the wide bolt pattern
Fuel Pressure Regulator x 10, B,D, all kinds
Stock plug wires x 8 B-series D-series
OBD1 injector clips (plugs) and partial harness
OBD2 injector clips (plugs) and partial harness
B20 engine harness, OBD2, LS should be the same?
Seats belts, front, back, everything, for Integra & Civic's
Some Stock Prelude/Accord mounts
Lots of AC lines for 92 and up civic
Upper A-arms, Civic & Integra
Front shock forks
T3 turbo exhaust housing – 5 bolt flange - NO 4 bolt
T4 turbo polish housing x 2, don't know the sizes.
2000 Honda Accord V6 Starter, brand new in box!
Spare tires, integra & civic x 4
H22 VTEC cams w/ cam stock cam gears
H22 VTEC starter
H22 VTEC crank, 96
60" piping for header back for an integra or civic
Nissan 240 hood S13, $20
Nissan 240 driverside and passenger side windows., $20 each
S13 Nissan ECU, KA20DE motor, $20
"Y" manual switch exhaust pipe, cast iron, & lever
Motorized scooter, suspension
2001 - 2005 BMW M3 passenger side fog light
2001 - 2005 BMW M3 front bumper, needs repair
2001 - 2005 BMW M3 passenger side headlight, HID, broken tabs good for DIY HID
2001 – 2005 BMW M3 – Eibach springs, only rear, lowers .9”
2001 – 2005 BMW M3 – Vogtland Springs, front lower 1.2” and rear .8”
2001 - 2005 BMW M3 – Tein S Springs, Front lower 1.5” and rear 1.3”
<U>WTT: I want or trade for</U>
94 and up Acura Integra Full interior, black, coupe
B-series turbo kit. – or incomplete kit.
Supercharger
Type R Front end JDM
2001 and up E46 BMW one Headlight – need one more for HID Conversion
<U>Free to those who bought from me:</U>
Old school 60CC bike, not running, rusted up, Free
Driver side 94 Integra tail light slight crack, Free
90 B18A bare head, Free
96 and up, Honda Civic Door panels, white pillars and gray -Free
I have lots of pictures; you can email me Mugen21@socal.rr.com. Please be specific, year/model/make/engine/and your offer of how much.
IF YOU TOOK THE TIME TO READ THIS ENTIRE POST, PLEASE BUMP!!! I’d be surprise if you did go down this far! If you did, low ballers are welcome but may not be acknowledged! NO FLAMING please. GO Flame somewhere else.
Modified by Tuan at 4:08 PM 4/3/2006
Old Aug 23, 2005 | 01:00 PM
BERT-O's Avatar
Default Re: LARGEST for sale list ever! B-series, D-series, CARS, always updated!!!! (Tuan)
Old Aug 23, 2005 | 10:46 PM
beelzebub's Avatar
Default Re: LARGEST for sale list ever! B-series, D-series, CARS, always updated!!!! (BERT-O)
Subscribed!
Old Aug 23, 2005 | 11:24 PM
hasback*'s Avatar
F*CK THIEVES!
Default Re: LARGEST for sale list ever! B-series, D-series, CARS, always updated!!!! (beelzebub)
bump for tuan. bought a cargo cover off him a long time ago.
Old Aug 24, 2005 | 01:37 AM
methos713's Avatar
wow
Old Aug 24, 2005 | 02:52 AM
EnjoyTheRideDC2's Avatar
Bump!
Amd Pmed!
Old Aug 24, 2005 | 10:19 AM
imnotted's Avatar
bump & emailed
Old Aug 25, 2005 | 12:09 PM
Tuan's Avatar
Default Re: (imnotted)
got it!
Old Aug 27, 2005 | 11:11 AM
Tuan's Avatar
Just got in a driver side fender! for a 94-2001 , primered black
Old Aug 29, 2005 | 10:02 AM
Tuan's Avatar
just added a "96-99 GSR OBD2a P72 ecu'
Old Aug 30, 2005 | 11:49 AM
blkhtch98's Avatar
bump
Old Aug 30, 2005 | 12:12 PM
Tuan's Avatar
Default Re: LARGEST for sale list ever! B-series, D-series, CARS, always updated!!!! (blkhtch98)
thanks!!!!
Old Aug 30, 2005 | 03:15 PM
Tuan's Avatar
Updated:
- 1999 OBD2a, GSR Complete swap! Bone stock, axles, shiftlinkage, distributor, ecu, PLUG & PLAY. Have paperwork for it also! $2,900 firm.
- Driver side fender.
- B20 VTEC complete SWAP, B16a 2nd gen head, GSR hydro tranny, lighten flywheel (or 8lbs clutch specialties aluminum flywheel, clutch specialties 6 puck non-spring hub, new pilot bearing, ITR intake manifold, CTR intake Cam, AEM sprockets, axles, ITR gold shiftlinkage, distributor, alternator, starter, chioce of P61 or P28, all motor mounts w/ polyurethane inserts, Pm me for price. Currently in car for test drives and etc. will throw in extras! asking for offers! will piece out for the right offered prices
Old Aug 30, 2005 | 04:01 PM
808_si's Avatar
how much for the type r valve cover. and bump for the biggest forsale list i've seen!
Old Aug 30, 2005 | 06:46 PM
Garcia-Racing's Avatar
bump fo a lot o chit!!!
Old Aug 30, 2005 | 06:54 PM
dohcVTECeg2's Avatar
Default Re: LARGEST for sale list ever! B-series, D-series, CARS, always updated!!!! (Garcia-Racing)
pm'ed
Old Aug 30, 2005 | 07:30 PM
Tuan's Avatar
Default Re: LARGEST for sale list ever! B-series, D-series, CARS, always updated!!!! (dohcVTECeg2)
all as replied!!! thanks!
Old Sep 1, 2005 | 09:38 AM
Tuan's Avatar
NEED TO GET RID OF BY END OF THE MONTH!!! 1994 Acura Integra LS- coupe, Salvage title, White, 114K miles on the chasis, less than 50K on motor, less than 4K on build up, , AC, Sunroof, PW, ABS, B20 VTEC, B16a 2nd gen head, GSR tranny, lighten flywheel, clutch specialties 6 puck non-spring hub, new pilot bearing, 98 front end, 60mm mandrel bent piping, high flow cat, gutted, w/ stock muffler, with throw in an aftermarket muffler, APExi VTEC Controller - blue, Type R intake manifold, Type R valve cover, Tokico shocks, progress springs lowering springs, tokico 4 way-adjustable shocks - white, Power steering,CD,Gray interior, floor mats, Code Alarm, keyless entry, MOMO shift ****, short shifter, Polyurethane motor mount bushings, Type R front sway bar, Spoon mirrors, will also include stock springs, $3500 firm!!!. <U></U>- with bronze 16” GT3s, add $300. I will part with anything or sell the shell alone or motor alone. Give me offers. Will throw in lots of extras (muffler, sway bars, blah blah)
Old Sep 3, 2005 | 02:16 PM
Tuan's Avatar
UPDATED PARTS ADDED TO THE LIST as of 9/3/2005
- DC strut bar, for 94 and up Integra and 92 and up Honda Civic's
-Honda Civic hatchback, Floor mats, don't know if it's the same with coupes
- Cheap straight wanna be N1 muffler
Old Sep 3, 2005 | 03:04 PM
blackstar's Avatar
war all of the time......
GREAT SELLER!!! i've done business with him many times, he's got every random bolt, mount, or bracket u could need
Old Sep 4, 2005 | 02:35 PM
Tuan's Avatar
Default Re: LARGEST for sale list ever! B-series, D-series, CARS, always updated!!!! (blackstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackstar &raquo;</TD></TR><TR><TD CLASS="quote">GREAT SELLER!!! i've done business with him many times, he's got every random bolt, mount, or bracket u could need
thanks man... hey how come i'm not on your seller's list?
Old Sep 5, 2005 | 12:45 PM
Tuan's Avatar
ttt
Old Sep 5, 2005 | 01:14 PM
1slocrx's Avatar
got any crx doors for sale?
Old Sep 5, 2005 | 07:51 PM
Tuan's Avatar
Default Re: (1slocrx)
Your in OHIO, that's gonna be tuff to ship. Give me a wild offer for them.
Old Sep 5, 2005 | 07:58 PM
allmotorteg_96's Avatar
Default Re: (Tuan)
damn where do you find all of theses parts
