95 Honda Accord Idling with the A/C
Ok I read my service manual and idled my car to spec. BUT when I put the A/C it drops it down to where I know and can feel it needs to be idled up. Is there another setting I need to change (Like fast idle) or something to keep it at the correct idle speed even when the A/C is on ?
Thanks !
Thanks !
THE ECU SHOULD adjust for the a/c being by moving the idle up. I could check to ensure that the ICV is working properly
You could also check if the AC is overcharged or the compressor is going out. Maybe the compressor is too much drag compared to what it's supposed to be?
se93
Jul 22, 2002 09:10 AM
