fuel rail leaking
Old Aug 23, 2005 | 11:08 AM
zman's Avatar
Default fuel rail leaking
finished a 1st gen b16 swap into a eg sedan and we're having problems with gas leaking from the fuel rail.
It leaks from where the fuel hard line attaches to the rail. We tried every combination of washers, big one on top small one on the bottom, small one on top big one on bottom, two on top, two on the bottom....didn't really make a difference.
We tried swapping the fuel rail for a b18a rail and the FPR is right where the IAT sensor is, so we de-pinned the IAT and ditched the plug so we could fit the FPR on.
The problem with the rail that came on the b16 was that the stud that the hardline attaches to was too short and the little end cap wasn't fitting properly. We tried 3 different caps with no luck. Tried 3 different rails without any real luck. We ended up using the b18a rail with a washer on the top and one on the bottom, it doesn't leak as bad as the other combinations but it still is slowly slowly leaking out.
Do we need a different rail....like the 2nd gen b16 rail?
Thanks h-t.
Old Aug 23, 2005 | 11:10 AM
hoffman4684's Avatar
I have a 2nd gen JDM b16a with a similar problem. I was told to replace the fuel rail and maybe the line. You can get both for under $200 easily.
Old Aug 23, 2005 | 11:39 AM
zman's Avatar
Default Re: (hoffman4684)
not what i wanted to hear, but thanks.....anyone else with input?
Old Aug 23, 2005 | 12:20 PM
blk007's Avatar
Default Re: (zman)
come on people...please help...it's my car save me from blowing up...somebody mentioned we should try a b series hardline? isn't it the same as the one on my eg? suggestions..anyone who experienced this problem and fixed it...please help.thank you
Old Aug 23, 2005 | 12:40 PM
Marauder's Avatar
Default Re: (blk007)
Are you using a sealing washer that's meant for the fuel rail?
Just had to ask, since you only mentioned washers, and they need special sealing washers. Everytime you take off the fuel line you are supposed to put in new ones, since once they have been tightened, they crush which causes the seal.
Old Aug 24, 2005 | 09:18 AM
blk007's Avatar
Default Re: (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">Are you using a sealing washer that's meant for the fuel rail?
Just had to ask, since you only mentioned washers, and they need special sealing washers. Everytime you take off the fuel line you are supposed to put in new ones, since once they have been tightened, they crush which causes the seal. </TD></TR></TABLE>
mmm..u're the 3rd person saying that...we didn't, i am gonna get a new cap and washers from honda.thanks
Old Aug 24, 2005 | 10:28 AM
1.8EG-T's Avatar
Just had to ask, since you only mentioned washers, and they need special sealing washers. Everytime you take off the fuel line you are supposed to put in new ones, since once they have been tightened, they crush which causes the seal. </TD></TR></TABLE> Best advice I have read...
MastaFlyMason
Nov 22, 2017 07:56 PM
94SuperLudeSI
Aug 19, 2005 09:05 PM
Cractos
May 2, 2004 06:11 PM
philly blunt
Apr 20, 2004 05:54 PM
