another lca problem, not the bold on the shock ---->?
Old Aug 23, 2005 | 09:25 AM
_noname_'s Avatar
Default another lca problem, not the bold on the shock ---->?
trying to change out the lca's and shock/struts.
the problem lies with the bolt, holding the lca to the hub. it is hard as #$%*.
i've circled the bolt in green.
i've tried almost everything: air gun it, pb blastered it, breaker bar'd it,..etc....
i'm hessitant about tourching it and then trying to drill it out.
any suggesstions.?
Old Aug 23, 2005 | 09:31 AM
integra15's Avatar
Default Re: another lca problem, not the bold on the shock ---->? (skx)
I would suggest continuing to spray it with WD40 or whatever, letting it soak in. then try air ratchet. Or try hitting it with a hammer a bit to loosen up the threads?
Old Aug 23, 2005 | 09:32 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
I've never had a prob with that bolt. Try heating it up....
Old Aug 23, 2005 | 12:42 PM
nickG's Avatar
if you can tell its not seized, put a big *** pole on the end of the wrench/ratchet and get way more leverage...itll break it loose
if its seized, youll know it when the bolt head snaps off...
Old Aug 23, 2005 | 12:43 PM
xteg95's Avatar
Default Re: another lca problem, not the bold on the shock ---->? (nickG)
I ended up torching mine and using an air gun...came right off.
TORCH THAT SUCKER
Old Aug 23, 2005 | 12:49 PM
EG_H2B's Avatar
Default Re: another lca problem, not the bold on the shock ---->? (xteg95)
the torch works great
Old Aug 23, 2005 | 01:23 PM
_noname_'s Avatar
Default Re: another lca problem, not the bold on the shock ---->? (JS_TypeR)
yeap, think i'll go get a torch and fire that muthafo.
Old Aug 23, 2005 | 03:46 PM
Racermech's Avatar
just do a little heat at a time. and only hat up the threads. They are what is stuck, not the head
Old Aug 23, 2005 | 06:40 PM
stumpyf4's Avatar
Default Re: another lca problem, not the bold on the shock ---->? (Racermech)
That bolt along with the shock bolt tends to rust to the inner can of the bushing resulting in the bolt shaft being seized to the bushing. Mostly likely you're gonna break the head off that bolt just like you did the shock bolt.
If you want to get the control arm out you're gonna have to get the sawzall and cut through the bushing... sign up on Team-Integra.net, they have a article on how to do it.
That factory scissor jack is worthless...get some jack stands
Old Aug 23, 2005 | 07:57 PM
_noname_'s Avatar
Default Re: another lca problem, not the bold on the shock ---->? (stumpyf4)
yeah, that factory jack is pretty shitty. but i got some real jack stands under there some where. dont worry i wouldnt work under there if i didnt have it securely lifted.
will torch the bolt tomorrow and see wat happens.
Old Sep 7, 2005 | 06:38 PM
_noname_'s Avatar
alright, i need some more tips.
i have tried torching the fugger and still wont budge.
plus the driver's side bolt if fricken striped now.
HELP!!!!!!!
here are some pics:
this is where i am torching..
heres the striped fugger
and how the hell do you get this bolt off, this plastic piece is in the way
and heres what 4+ years of driving without cleaning will do:
any help would be much appreciated.
Old Sep 8, 2005 | 07:34 AM
huntarrr's Avatar
bump because my shock bolt was seized and i just broke off the head
im having trouble as well.
Old Sep 8, 2005 | 08:02 AM
I got a honda's Avatar
Default Re: another lca problem, not the bold on the shock ---->? (vsm98civic)
i had these same problems i just had a professional come in and fix it...........
Old Sep 8, 2005 | 08:12 AM
xteg95's Avatar
How long did you torch it for?
Old Sep 8, 2005 | 02:05 PM
_noname_'s Avatar
i guess, i'll have to torch this sucker as long as it takes.
Old Sep 8, 2005 | 02:18 PM
BlackLudeSi's Avatar
When its hot enough it will be glowing red
Old Sep 9, 2005 | 08:56 AM
_noname_'s Avatar
Default Re: another lca problem, not the bold on the shock ---->? (BlackLudeSi)
will try doing that.
would be a lot easier if i had the car jacked on a lift.
but will have to do for now.
Old Sep 15, 2005 | 06:24 AM
_noname_'s Avatar
well, i finally got one of the bolts off after torching that sucker for a long **** time. but the other side, the stripped side, i bought to bolt out kit at sears to get that badboy out. upon trying i fricken broke it. now the only solution i can see is drilling out that fugger.
will get pics of this later...
Old Sep 15, 2005 | 07:22 AM
xteg95's Avatar
damn dude still having problems!?!
Careful if you drill that sucker out cause it's threaded out on the other side...that's the worst dealing with that ****, well GL man.
Old Sep 15, 2005 | 09:19 AM
integra15's Avatar
Get some good drill bits, your going to need they. But it is not impossible, I did the same on my old car. Drilled it out and used a longer bolt and nut to hold it together when I reassembled it.
jksmith
Jul 25, 2009 07:50 AM
supermario680
Suspension & Brakes
Feb 9, 2008 10:07 AM
94hondacivicvtec
Aug 28, 2007 05:34 PM
Batoutahell
Oct 15, 2002 04:33 AM
Peter K
Apr 19, 2002 05:53 AM
