JDM CRX SIR CLUSTER HELP
Old Aug 23, 2005 | 07:17 AM
BraydenR's Avatar
Default JDM CRX SIR CLUSTER HELP
I have everything just need to know for the electric speed sensor the 3 wires are for what one i know goes to the cluster but which one
i just need a wiring diagram for what the 3 wires mean on the VSS plug and where do they go
thanks in advance
Old Aug 23, 2005 | 08:56 AM
APEX CRX's Avatar
Default Re: JDM CRX SIR CLUSTER HELP (BraydenR)
there are a few different VSS's D and B series but the wiring is the same
black is ground, middle wire is power and rt wire is signal. ground is self explanatory, power is to a 12v switched source and signal should go to Vss signal depending on your motor/wiring I believe its either B16 or B10 on the ECU wiring
eddiebuiltEK.
Aug 13, 2009 12:41 PM
hatchback SI
Mar 28, 2009 10:51 AM
ballermc5
14
Oct 28, 2006 03:52 PM
