CTR wheel bearing for rear?!
yeah so I have a ctr 5lug on my car, my rear driverside bearing is bad and I do not know what to replace it with? I only can find ITR uses 98+crv and 92-00 civic use the same, so would 92-00 work for me?
TIA
Rhett
TIA
Rhett
last time i checked the rear was a hub and bearing assembly, so you would need to try an ITR setup. (this was on a 92-95 civic hatch with rear disks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">last time i checked the rear was a hub and bearing assembly, so you would need to try an ITR setup. (this was on a 92-95 civic hatch with rear disks)</TD></TR></TABLE>
hmmmm, ok cool, I appreciate it. anymore info anybody?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MC_Rhett_Meister »</TD></TR><TR><TD CLASS="quote">need help</TD></TR></TABLE>
honestly WTF else do you need help with? go to the auto parts store take your hub with you and see if the ITR one match up. Id bet money it does.
honestly WTF else do you need help with? go to the auto parts store take your hub with you and see if the ITR one match up. Id bet money it does.</TD></TR></TABLE>
whoa! sorry duder, first of all the hub isnt off yet, the car is still driven, would like to sit in my home and find out before going through the trouble if at all possible and if the question is answered it will be reference for the future. which it will be when i replace it
I replaced the bearings/hubs on my CTR 5 Lug with USDM ITR parts,Both front and rear.
Everything is exactly the SAME, even the part numbers.
whoa! sorry duder, first of all the hub isnt off yet, the car is still driven, would like to sit in my home and find out before going through the trouble if at all possible and if the question is answered it will be reference for the future. which it will be when i replace it</TD></TR></TABLE>
I'd replace wheel bearings ASAP, once it starts to go out it can and will fail. And "going through the trouble", are you serous? you just take off the old hub, (requires taking off the wheel, and then the bearing nut) and ding ding its off.
Mr.OB*GYN_Rhett
Aug 25, 2005 06:51 AM
doublethink
Nov 8, 2004 01:06 PM
Steve91
Aug 26, 2002 02:51 PM
