Ls running like a single
Old Aug 22, 2005 | 09:51 PM
96LsBang's Avatar
Default Ls running like a single
Can anyone help me out? I have a 96 Ls with intake, 2 and 1/2 catback exhaust and a short shifter. My car was running great for about a month then i started to hear a knocking or ticking noise under the hood, so i figured it was a valve tick so i got them adjusted but after about 20 mins they started again now im loosing to stock single vtec's by 2 or more cars i was wondering wat should i do or wat could be the problem please give me some feeback
Old Aug 22, 2005 | 09:53 PM
sohcvtec1995's Avatar
Default Re: Ls running like a single (96LsBang)
Any cels? and also when was the last time you did a tune up.
Old Aug 22, 2005 | 09:58 PM
96LsBang's Avatar
Default Re: Ls running like a single (sohcvtec1995)
never been tuned since i had it but i bought it about 2 months ago do you think thats the problem it seems like when i punch it hard it goes no where
Old Aug 22, 2005 | 10:00 PM
Thats a plae to start, and if thats not it at least you know that it has had a tune up. Also could be your timeing, check that as well. or even you throttle cable, make sure its tight, and that you are getting full throttle.
Old Aug 22, 2005 | 10:04 PM
96LsBang's Avatar
THANKS FOR THE TIPS
Old Aug 22, 2005 | 10:06 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96LsBang &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone help me out? I have a 96 Ls with intake, 2 and 1/2 catback exhaust and a short shifter. My car was running great for about a month then i started to hear a knocking or ticking noise under the hood, so i figured it was a valve tick so i got them adjusted but after about 20 mins they started again now im loosing to stock single vtec's by 2 or more cars i was wondering wat should i do or wat could be the problem please give me some feeback</TD></TR></TABLE>
Hmmmm.....have you taken apart the valve train to look inside? Checked out other internals? Sensors maybe? Though it wasn't mentioned, have you tried running the car at idle with the hood open and trying to figure out exactly where the ticking was coming from? That's where I'd begin the troubleshooting process.
Old Aug 23, 2005 | 06:25 AM
fast95se's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96LsBang &raquo;</TD></TR><TR><TD CLASS="quote">now im loosing to stock single vtec's by 2 or more cars i was wondering wat should i do or wat could be the problem please give me some feeback</TD></TR></TABLE>
Personally, I wouldn't judge my engine's performance by how far you're winning or losing street races. There are waaaaayy too many variables there. For all you know that guy could've drank 5 red bulls right before
Unless you feel confortable tearing things apart on your car, I would start by taking it to a mechanic
Old Aug 23, 2005 | 09:43 AM
Could also be your cat is starting to clog, and thats what the sound is that your hearing. Who knows. Just a thought.
Old Aug 23, 2005 | 10:41 AM
old_school_dohcvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96LsBang &raquo;</TD></TR><TR><TD CLASS="quote">i started to hear a knocking or ticking noise under the hood, so i figured it was a valve tick so i got them adjusted but after about 20 mins they started</TD></TR></TABLE>
have you ever mishifted before?
Old Aug 23, 2005 | 10:45 AM
svtec's Avatar
L D E S
Default Re: Ls running like a single (fast95se)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95se &raquo;</TD></TR><TR><TD CLASS="quote">For all you know that guy could've drank 5 red bulls right before
for all you know he could have put crunk juice in his engine and that is why you lost.
Old Aug 23, 2005 | 11:01 AM
outofstock's Avatar
Default Re: Ls running like a single (svtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">
for all you know he could have put crunk juice in his engine and that is why you lost. </TD></TR></TABLE>
A-Yeaaaaaaaaaaaaaaaaaaaaaaa
Old Aug 23, 2005 | 11:03 AM
rough_draft's Avatar
knocking? does it have oil?
Old Aug 23, 2005 | 11:31 AM
svtec's Avatar
L D E S
Default Re: Ls running like a single (outofstock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outofstock &raquo;</TD></TR><TR><TD CLASS="quote">A-Yeaaaaaaaaaaaaaaaaaaaaaaa</TD></TR></TABLE>
Old Aug 23, 2005 | 12:14 PM
Sam92Teg's Avatar
Check to see if your cam timing jumped a tooth on the belt. It can make your car run like *** and your valve train will be noisey.
Old Aug 23, 2005 | 12:24 PM
96LsBang's Avatar
i've miss shifted a couple of times when i first drove the car but no more than 3 times
b20vteclsintegra
Oct 27, 2011 11:33 AM
Defiant_dc
Sep 25, 2008 06:05 PM
JuicyJDM
Jan 18, 2005 06:38 PM
johnnyxblaze
Jan 31, 2003 09:06 AM
widecoupe
Oct 2, 2001 07:54 AM
