need some advice on where 2 get stuff
hey i have a 00 civic ex and im nearing completion on the lil cosmetic things i needed b4 i got a new engine... not wastin my time with the y8... but im getting stuck on the gsr or the b16 i want a straight swap (no k motor) so im wondering which of these would be best built with turbo so far engine wise i have a ram air intake and a 3" exaust system (not on it) needs 2 b welded all parts here tho and with either of these which site would you say is cheapest for the swap (with sensors n what not) i mean if it needs a few things w/e i just dont want basic engine + tranny... thanx
regardless of what you want, use hmotorsonline.com
you wont get bs'd by them. there are cheaper places, and you might be a lucky one and get a good motor, but those guys are straight up.
also, go for the b18c, higher displacement and longer gears are good for a turbo. you're not gonna keep the short ram intake when you swap [ well maybe the cone filter, but not the piping ], and the 3" exhaust is good enough, if not a bit excessive. 2.5" to 3" is generally right for a turbo exhaust system.
the b16 has a better rod length to stroke ratio in terms of max rpm. it likes to rev, which suits it better for n/a. not saying you cant or shouldn't turbo a b16, but the motor doesnt lend itself as well. also, because the b18 is .2 liters larger, the b18 will be making more torque n/a or boosted. the b16 tranny is shorter ratio, so it'll accel quicker- if you can handle it. since you're going for boost, your torque levels will be at a point where you'll only have wheelspin. if you can manage it, the b16 tranny is great. but wheelspin tends to be the reason why boostheads lean toward the gsr tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iaredavid »</TD></TR><TR><TD CLASS="quote">regardless of what you want, use hmotorsonline.com
the b16 has a better rod length to stroke ratio in terms of max rpm. it likes to rev, which suits it better for n/a. not saying you cant or shouldn't turbo a b16, but the motor doesnt lend itself as well. also, because the b18 is .2 liters larger, the b18 will be making more torque n/a or boosted. the b16 tranny is shorter ratio, so it'll accel quicker- if you can handle it. since you're going for boost, your torque levels will be at a point where you'll only have wheelspin. if you can manage it, the b16 tranny is great. but wheelspin tends to be the reason why boostheads lean toward the gsr tranny.</TD></TR></TABLE>
Everything he said. So basically what I would say x2.
afsymms
Honda Civic (2001 - 2005)
10
May 9, 2006 01:03 AM
EL-Teg98
Dec 29, 2001 08:37 PM
