wont start help!!!
Old Aug 22, 2005 | 08:07 PM
sycamore
Guest
Posts: n/a
Default wont start help!!!
so my car wont start first there was no power going to the ecu then i put a new main relay in so i got power to the ecu and now it wont do any thing i does not prime the fule and dash lights get dim and when you turn on the heater it changes the brightness of the dash lights i think it is the ignition switch. any one eles have this problem. o by the way i have a 91si....
Old Aug 22, 2005 | 11:10 PM
.Grimace's Avatar
footwork mastery
Default Re: wont start help!!! (sycamore)
that sucks alex hope you get it fixed man. btw....did my old exhaust work good for you???
Old Aug 23, 2005 | 06:15 PM
sycamore
Guest
Posts: n/a
idk i havent weled it up yet not much nose when my car does not start. but thanks
Old Aug 23, 2005 | 08:07 PM
b18_crx's Avatar
does motor turn over?
start with the basics
1 check fuel
2 check spark
3 check timing
assuming ur not dumb or anything have u checked to see if ur battery is working fine? lights just dont dim....they dim for a reason
Old Aug 24, 2005 | 11:03 AM
sycamore
Guest
Posts: n/a
when i turn the heater thing the lights dim that is why i asked.
Old Aug 24, 2005 | 12:26 PM
DUFFM4N's Avatar
Default Re: (sycamore)
**** all the bullshit...swap the motor and shoot the old one
Old Aug 24, 2005 | 07:55 PM
sycamore
Guest
Posts: n/a
so now im not getting power to anything.here is what i have done so far.
checked all grounds
new main relay
cluch relay
checked all fuses
different pr4
so im out of ideas so some one help!!!!
Old Aug 25, 2005 | 12:52 PM
DUFFM4N's Avatar
wow i just had a small case of deja vu
Freemananana
Sep 11, 2014 12:13 AM
mr civicky
Apr 29, 2012 08:49 AM
mike865
Dec 14, 2010 11:37 AM
A_Vigor
Acura TL, RL & ZDX
Mar 16, 2008 04:24 PM
96integraLS
Oct 30, 2004 05:23 PM
