Z6 IN 89 CRX SI
alrighty,i am going to be putting a d16z6 in my 89 crx si. can i use the stock radiator and hose or will i have to change it to something else,if i will have to change it then i will prob just get a alluminum one.( i cant spell). is there anything else i might need to get or knw? i knw about the drivers mount how u have to cut the **** out to make it fit. anything else guys
thanks
me
thanks
me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowjdmcrx »</TD></TR><TR><TD CLASS="quote">alrighty,i am going to be putting a d16z6 in my 89 crx si. can i use the stock radiator and hose or will i have to change it to something else,if i will have to change it then i will prob just get a alluminum one.( i cant spell). is there anything else i might need to get or knw? i knw about the drivers mount how u have to cut the **** out to make it fit. anything else guys
thanks
me</TD></TR></TABLE>
you don't have to change ****....just the z6 you are putting in..
thanks
you will need to swap the engine mounts and use the ones off your stock d16a6. The upper radiator hose is also different.. you can get a straight piece of generic hose and it will work perfectly with your stock radiator. you can even run the z6 off your stock pm6 and get a VAFC and have near stock driveability
i chose a d16z6 over a d16y8 because the y8s seem to be very prone to spinning bearings
i choose the z6 b/c for some reason to me i just like the z6 better,i think it is abetter engine.i was kinda debating on using my a6 bottum end but i dont want to have to be out a motor for a long time so i will just use the z6. i will use a y8 intake if i dont use a skunk 2. i dont knw,haha. bad day today. but well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">The upper radiator hose can be trimmed a little, that way it isn't all squished foward.</TD></TR></TABLE>
Actually, all you have to do is swap the upper radiator hose neck for a 88-91 version. That way, you can use all stock hoses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef four door »</TD></TR><TR><TD CLASS="quote">
Actually, all you have to do is swap the upper radiator hose neck for a 88-91 version. That way, you can use all stock hoses.</TD></TR></TABLE>
just make sure u replace the gasket or use gasket maker
Akeem Willis
May 16, 2018 02:18 PM
h22_crx
Nov 11, 2005 11:22 AM
STP_crx123
Nov 2, 2005 03:58 PM
CRX_GUY_123
May 31, 2004 05:24 AM
Good luck with yours
