Weird idle and starting problem?
Old Aug 22, 2005 | 05:54 PM
CelicaGT-S's Avatar
Default Weird idle and starting problem?
The car will crank when it wants...And when it cranks it sounds like a scrapping noise, then it'll crank over...Is the timing off? Or does it have something to do with the starter?...Also how exactly do i set the idle?..I read in Chiltons, that u have to disconnect the eacv and to reset, remove the hazard fuse for 10 seconds...But it's not makin a big difference...Any help guys?...Any advice will help...!!!Thanx
Old Aug 22, 2005 | 06:05 PM
ewaugh's Avatar
Default Re: Weird idle and starting problem? (CelicaGT-S)
I'd say the starter. Pull it off and have them test it. Take the battery with you too, can't hurt.
Old Aug 22, 2005 | 07:26 PM
Jonny Black's Avatar
Default Re: Weird idle and starting problem? (ewaugh)
there is a ground on your thermostat. try making it better..like run another ground wire from it to a good location. I was having the same problem not to long ago. starts great now.
JdmSpecTeggy
22
Oct 15, 2009 10:04 AM
ncskate
Feb 25, 2005 10:00 AM
OneFastLS
Jul 17, 2002 02:40 PM
