hey guys anyone know what a sp sensor stands for? 99 civic, its on the same fuse as the alternator
i'm looking into this for a friend who is a tranny specialist, and yes i searched through 874 archived sensor topics already, its for a 99 civic, the fuse for the alternator and sp sensor ? keeps blowing, he is trying to trace the problem and i have no idea what the sp sensor stands for, if anyone can help me with this it would be much appreciated, thanks in advance! for any help.
same weird **** happend to me. you knwo what it was:
the intake air temp. sensor.
check that.
check that.
According to the Helms, the only fuse that the alternator is hooked to is Fuse 15 (7.5A) in the under-dash fuse relay. This fuse is also responsible for the VSS (vehincle speed sensor) EVAP 2-way valve, O2 sensor primary, EVAP control canister and purge valves, and the ECU. If it keeps blowing, then you might have a wire grounding somewhere it is not supposed to. I hope this helps.
iKhmaiFoSho
Jan 6, 2006 01:56 PM
who-got-rice
Aug 24, 2005 06:34 PM
9WON4
Jan 27, 2002 10:49 PM
