so what's the deal
Old Aug 22, 2005 | 02:54 PM
migizzel's Avatar
Default so what's the deal
i have replaced my batt 3 times in the last month it just dies on me i allready check the alternator is good, rewire the ground with new wire,put brand new terminals basically everything is checked but the batt keeps going out i even got one from a diffrent parts store im i missing somthing please help!!!!!!!
Old Aug 22, 2005 | 03:06 PM
RCautoworks's Avatar
Default Re: so what's the deal (migizzel)
You have a parsetic draw some where, meaning something is remaining on while the car is off.
Old Aug 22, 2005 | 03:14 PM
migizzel's Avatar
Default Re: so what's the deal (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">You have a parsetic draw some where, meaning something is remaining on while the car is off. </TD></TR></TABLE>
so how do i check to see where is comming from?
Old Aug 22, 2005 | 05:03 PM
elrandeeto's Avatar
i think u can do it by puttin a volt meter on your battery then start pulling fuses and putting them back in . and when the voltage goes up youve found it . i think the normal draw on the battery like from the clock , radio presets and ecu are like .32 or .64 cant remeber for sure its been a long time hopefully someone can chime in and give u exact amount . pretty much if the voltage goes up on any fuse besides the radio youve found it .
so you turn off your car wait like ten minutes then do the above
Old Aug 22, 2005 | 05:33 PM
CRX Toad's Avatar
Default Re: so what's the deal (elrandeeto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elrandeeto &raquo;</TD></TR><TR><TD CLASS="quote">i think u can do it by puttin a volt meter on your battery then start pulling fuses and putting them back in . and when the voltage goes up youve found it . i think the normal draw on the battery like from the clock , radio presets and ecu are like .32 or .64 cant remeber for sure its been a long time hopefully someone can chime in and give u exact amount . pretty much if the voltage goes up on any fuse besides the radio youve found it .
so you turn off your car wait like ten minutes then do the above </TD></TR></TABLE>
Old Aug 22, 2005 | 06:50 PM
Suck my DX's Avatar
Default Re: so what's the deal (CRX Toad)
so which is it .32 or .64?
ca177or4
Jul 20, 2006 08:07 PM
stock4now
Jun 9, 2006 01:19 PM
westcoastEJ1
May 8, 2006 11:16 AM
fanta!
Dec 7, 2005 10:52 AM
EG6[B16A1]
11
Jun 29, 2003 07:25 PM
