need help quick from full race traction bar users
Old Aug 22, 2005 | 02:19 PM
BoostR41's Avatar
Default need help quick from full race traction bar users
did you have any issues with them rubbing the tire at all. I haven't put the car down on the ground yet but rubs about 1/4 turn before lock? can I mount them to a bolt higher on the LCA instead of the wishbone to clear the tire?
it is a stock height ITR
Old Aug 23, 2005 | 06:48 AM
DaveF's Avatar
Default Re: need help quick from full race traction bar users (BoostR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">did you have any issues with them rubbing the tire at all. I haven't put the car down on the ground yet but rubs about 1/4 turn before lock? can I mount them to a bolt higher on the LCA instead of the wishbone to clear the tire?
it is a stock height ITR</TD></TR></TABLE>
are you putting them on the lower shock bolt? i belive Full-Race designed their bars to be mounted on the other bolt, closer toward the center of the car. HTH
please correct me if im wrong.
Old Aug 23, 2005 | 06:57 AM
AllMoToRB18c's Avatar
Default Re: need help quick from full race traction bar users (Dturbocivic)
sorry to thread jack but i was lookin to buy a set of these used and the kid had to dent in his oil pan to get it to clear...is that normal?
Old Aug 23, 2005 | 07:12 AM
DaveF's Avatar
Default Re: need help quick from full race traction bar users (AllMoToRB18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMoToRB18c &raquo;</TD></TR><TR><TD CLASS="quote">sorry to thread jack but i was lookin to buy a set of these used and the kid had to dent in his oil pan to get it to clear...is that normal? </TD></TR></TABLE>
no, this is not normal, do you know if the user, had them installed on the chassis that they were designed for? also, which engine was the person running? are you sure that they were the Full-Race brand?
Old Aug 23, 2005 | 12:31 PM
BoostR41's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
please correct me if im wrong. </TD></TR></TABLE>
I am pretty sure it is supposed to be bolted to the wishbone bolt. could it be cause the car was off the ground and suspension unloaded that it touched?
Old Aug 23, 2005 | 12:54 PM
DxTrix's Avatar
http://full-race.com/installation.php
Here you go from the full-race site there should be pics of the install. Sorry I could not post them my comp is being a pain.
Old Aug 23, 2005 | 01:57 PM
skunked's Avatar
some have had problems clearing the h series oil pan with certain mount kits.
Old Aug 23, 2005 | 04:24 PM
BoostR41's Avatar
Default Re: need help quick from full race traction bar users (DxTrix)
I was wrong it is one bolt up from the wishbone. guess we will see if they clear in the morning
Mike Husted
Honda Civic (2001 - 2005)
Aug 7, 2013 02:48 PM
lunareg
Aug 30, 2010 11:47 AM
alb_accord
Mar 1, 2004 02:36 PM
smoky
May 14, 2003 08:02 AM
Heavy Pee
Oct 2, 2002 05:41 PM
