will my clutch and flywheel work?
Old Aug 22, 2005 | 01:35 PM
99sonicbluegsr's Avatar
Default will my clutch and flywheel work?
my question is, i have a dohc zc with a 89 dx tranny on it. i didn't like the gear ratios so i bought a 91 si tranny. will my clutch and flywheel work with the 91 tranny? sorry for the stupid question and yes i did search (a little).
Old Aug 22, 2005 | 01:50 PM
dr_latino999's Avatar
Default Re: will my clutch and flywheel work? (99sonicbluegsr)
Yes, quick information -
88 - 200mm Clutch - 21 Spline Transmission
89 - 200mm Clutch - 20 Spline Transmission
90 - 212mm Clutch - 20 Spline Transmission
91 - 212mm Clutch - 20 Spline Transmission
Old Aug 22, 2005 | 03:11 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99sonicbluegsr &raquo;</TD></TR><TR><TD CLASS="quote">my question is, i have a dohc zc with a 89 dx tranny on it. i didn't like the gear ratios so i bought a 91 si tranny. will my clutch and flywheel work with the 91 tranny? sorry for the stupid question and yes i did search (a little).</TD></TR></TABLE>
Yes it will work. And you do know that the DX and Si gear ratios are the exact same? The only different ratios between the Dx and the Si is the final gear ratio.
Old Aug 22, 2005 | 03:12 PM
Kwicko's Avatar
Default Re: will my clutch and flywheel work? (dr_latino999)
What he said ^. Should work fine. The problems usually arise when trying to use an '88 tranny with an '89-'91 clutch and/or flywheel, or when trying to mix & match different year clutch & flywheel combos. But the '91 Si tranny should work perfectly with the '89 clutch and flywheel.
Mike
Old Aug 22, 2005 | 03:14 PM
Kwicko's Avatar
Default Re: will my clutch and flywheel work? (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes it will work. And you do know that the DX and Si gear ratios are the exact same? The only different ratios between the Dx and the Si is the final gear ratio.</TD></TR></TABLE>
Yeah, but what a difference. The Si's 4.25 FD just feels soooooo much better.
Mike
Old Aug 23, 2005 | 05:53 PM
thanks for the hepl
Old Aug 23, 2005 | 06:12 PM
dcgamez80's Avatar
New User
yes
Reason01
13
May 1, 2010 09:38 AM
crx69
Apr 10, 2005 05:33 PM
CRseXy
Jan 4, 2005 07:35 AM
racingant
Sep 6, 2004 08:08 PM
sohcvtec66
Nov 18, 2003 09:49 AM
