Code 20 ???
Old Aug 22, 2005 | 11:31 AM
hedtrip's Avatar
Default Code 20 ???
ok im geting code 20 ..eletrical load
what are some comman things 2 check ??
i've gone over my wiring .. & wasnt sure were 2 check.. 2 see what the problem is.. other then code flashing .. it seems 2 be driving fine .
btw . its a 88 crx hf with a y8
Old Aug 22, 2005 | 11:41 AM
B SERIES US's Avatar
Default Re: Code 20 ??? (hedtrip)
try checking to see if u have good grounds
Old Aug 23, 2005 | 12:59 PM
hedtrip's Avatar
i cheecked all my grounds ... still throwing 20
Old Aug 23, 2005 | 06:43 PM
zccr-xsi's Avatar
im throwing the same code.now my question is if i change the fuse box that is mounted on the dash will it fix it?
Old Aug 23, 2005 | 07:18 PM
CR_VtecCRX89's Avatar
Default Re: (vteckillenzc)
i've changed every thing i can still have code 20.....but i saw some thin on here that if yoou cut your ac wireing that it can cause a code 20 thats what i did not shure dose anyone npo?
Old Aug 23, 2005 | 07:50 PM
hedtrip's Avatar
hmm that might be it .. cause i cut my Ac plugs & lines & **** !!
Old Aug 23, 2005 | 09:22 PM
Default Re: (hedtrip)
well let me no when you fix it.....i dont have time right now.....work'n and ****..days off is thurs h opefully u figure it out bye then....hope thats it
Old Aug 24, 2005 | 05:57 PM
zccr-xsi's Avatar
i cut my ac lines and took all that out but it wasnt throwing it after i did it just came up couple dayz ago.
Old Aug 24, 2005 | 06:37 PM
hedtrip's Avatar
mine didn't start doing it untill a few days after .. ... i still havn't fucked with it yet .2 see if thats the problem ..haven't had time
lou1sette
Honda Civic (2006 - 2015)
Aug 6, 2018 06:37 PM
miguey310
Nov 21, 2010 09:24 PM
0ne-Cam
14
Aug 20, 2009 06:58 PM
zccr-xsi
Nov 4, 2005 10:36 AM
lsvtec42
Dec 19, 2001 10:11 AM
