done h22a swap, fuel not priming straight away??????????????????
Old Aug 22, 2005 | 10:46 AM
MarkC1500's Avatar
Default done h22a swap, fuel not priming straight away??????????????????
Hi, I have done my H22a swap into my Euro Accord (ce8) for the second time now, someone wrote my first car off. I have a P28 ECU.
Problem: When I turn the ignition on the fuel doesnt prime straight away, so obviously I cant start the car. How long it takes to eventually prime is completely ramndom. Somtimes I have to wait 2secs or maybe 10mins. Seems to take longer in cold weather, but not sure this is relevant. Other ECU's work fine.
Do any of you electricians out there know of any circuit board components that might change under different temps. I was looking at QM1 on the board, I'm not exactly sure what the component is called.
Thanks
Old Aug 22, 2005 | 11:33 AM
92acclude's Avatar
Default Re: done h22a swap, fuel not priming straight away?????????????????? (MarkC1500)
I have the same problem in my cb7 with a H22 swap. I normally just crank the engine til it starts. I have been wondering what it is. Anybody?
Old Aug 22, 2005 | 12:45 PM
skunked's Avatar
Default Re: done h22a swap, fuel not priming straight away?????????????????? (92acclude)
That happened to me when my stock pump starting to go out. I would have to turn the key on then off a couple of times until I heard the pump kick on. I highly doubt it's an ECU issue. How old is your pump?
Old Aug 22, 2005 | 01:26 PM
MarkC1500's Avatar
Like i said, If i plug in a different ecu off the old 2.0i it starts fine, straight away.
Old Aug 22, 2005 | 02:02 PM
92acclude's Avatar
Default Re: (MarkC1500)
I switched to a different P13, without a difference. My fuel pump is 13 years old. I had a feeling that might be it. That's why there is a Walboro sitting in my room, waiting to go in. Now if I can find the time to do it.
Old Aug 22, 2005 | 02:36 PM
MarkC1500's Avatar
Im the one who needs help here
Old Aug 22, 2005 | 06:36 PM
92acclude's Avatar
Indeed, sorry for the thread jack.
Bump for help for this guy. to a running H22
Old Aug 24, 2005 | 05:08 PM
Evil-EK's Avatar
Default Re: (92acclude)
If the problem goes away when you change out the ecu then you have cured your own problem. Does the car start every time with the old ecu? If so then just get a new p13.
ek9_ab
Feb 16, 2015 12:37 PM
Coupe92
Sep 7, 2011 07:01 PM
AccordTypeRH22a
Jul 31, 2009 06:31 AM
