MY launches are holding me back for hitting 12's
Old Aug 22, 2005 | 09:52 AM
ISPhuevos's Avatar
Default MY launches are holding me back for hitting 12's
Last CMI i went to, i ran 13.4@106. I had the most ****-up launches 2.1,2.0,2.3 and once 1.9. I make over 215hp so i know the slick arent to big (23/8/13) I have CTR tranny w/ lsd, omni, and full race cross member. I know the mph are good enough for 12's but i just the launch. Any help thanks!!!
THE CAR
1991 civic for door weigh 2270 stock
223hp 154tq
Old Aug 22, 2005 | 10:06 AM
sohcnyce's Avatar
Default Re: MY launches are holding me back for hitting 12's (ISPhuevos)
make your car go on a diet lol
Old Aug 22, 2005 | 10:23 AM
Supernatural's Avatar
the slicks are too big....
play with tire pressure....
Old Aug 23, 2005 | 03:54 PM
smokey2.0's Avatar
Default Re: MY launches are holding me back for hitting 12's (SUPERNATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPERNATURAL &raquo;</TD></TR><TR><TD CLASS="quote">the slicks are too big....
you think, i would have to know @ what rpm are you dropping the clutch!
Old Aug 23, 2005 | 04:11 PM
skunked's Avatar
Default Re: MY launches are holding me back for hitting 12's (smokey2.0)
that should easily be a 12 second ET. The 23's are a little on the big side but your 60's suck. How much pressure was in the slicks and what RPM were you launching at?
Old Aug 23, 2005 | 06:01 PM
CRX_Phantom1's Avatar
Default Re: MY launches are holding me back for hitting 12's (skunked)
try a 20" slick and work on your 60's
Old Aug 23, 2005 | 08:40 PM
SiR831's Avatar
Default Re: MY launches are holding me back for hitting 12's (CRX_Phantom1)
any of your buddies have some 22x8x13's that you can borrow? Saw you running last CMI
Old Aug 23, 2005 | 09:04 PM
sohcnyce's Avatar
Default Re: MY launches are holding me back for hitting 12's (SiR831)
the rims he is running he cant go lower then 7 psi cause the bead would breack.
cause when i put them on we tryed like 5 psi the bead wasnt holding. anyoen know where we can rota rb cheap ?
Old Aug 23, 2005 | 10:45 PM
beerbongskickass's Avatar
Default Re: MY launches are holding me back for hitting 12's (isphatch)
I have the same slicks and about the same power... launch off the rev limiter and you will hit 12's.
Old Aug 24, 2005 | 12:04 AM
JSpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isphatch &raquo;</TD></TR><TR><TD CLASS="quote">the rims he is running he cant go lower then 7 psi cause the bead would breack.
i dont think the problem is too much pressure...throw like 15 in there and go from there
Old Aug 24, 2005 | 12:47 AM
Maxime's Avatar
Do you have traction problems or does the car bog off the line?
If you dont have enough power for the slicks (too much traciton) try addind some PSI in slicks. May sound stupid but less traction could help your 60'.
Old Aug 24, 2005 | 01:14 AM
rjay8604's Avatar
Damn man you're making sick *** power. K-series? B20vtec? Great power though. Drop some weight, get the mph to like 107-108 and you could probably hit 12's with only a 2.0 60'. Great power though and 4 door = sleeper.
Old Aug 24, 2005 | 02:30 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Phantom1 &raquo;</TD></TR><TR><TD CLASS="quote">try a 20" slick</TD></TR></TABLE>
That may be a good idea. ^^^^. IMO, Using the shortest slick possible is the best scenario. The 23's ARE much to big for your setup. Even on 22x8's you'll have to run alot of pressure in them and launch very high. I've made many 120+ mph, 11 sec. passes on 22's so, in short slicks I trust
Phil
Old Aug 24, 2005 | 07:00 AM
skunked's Avatar
Default Re: MY launches are holding me back for hitting 12's (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
I ran 22's with my last setup with only 200whp, 12's all day. I agree that you should try and run the smallest slick possible but the 20's will spin too much from my experience with that amount of hp.
Old Aug 24, 2005 | 09:23 AM
93H22ACX's Avatar
launch higher....
i used 24.5x8x13 and ran 12.8-12.9@103-105mph with my H22.... 187whp when it was dyno tuned...
Old Aug 24, 2005 | 07:08 PM
SiKnezzALLmotor's Avatar
hey isp i can get u rotas homie holla at me
Old Aug 24, 2005 | 08:31 PM
STREETWERKZ's Avatar
slicks MAY be a little big.... but 20s might be too small.
what RPM are you launching at and again, does it spin or bog?
Old Aug 25, 2005 | 11:28 AM
blacllkllsi's Avatar
hmm.... I ran a 13.7 @108. What times do you think I can get with that trap speed? This was on stock tires w/ a 2.3 60 ft?
Old Aug 25, 2005 | 11:59 AM
sohcnyce's Avatar
Default Re: (blacllkllsi)
max hit us up and let us know
Old Aug 25, 2005 | 04:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacllkllsi &raquo;</TD></TR><TR><TD CLASS="quote">hmm.... I ran a 13.7 @108. What times do you think I can get with that trap speed? This was on stock tires w/ a 2.3 60 ft?</TD></TR></TABLE>
Mid 12's give or take a few...
Old Aug 25, 2005 | 04:24 PM
Default Re: (beerbongskickass)
i made 240+ and i knew my slicks were too big.....and those were 24.5x8.5x13
Old Aug 25, 2005 | 04:35 PM
skunked's Avatar
Default Re: (SUPERNATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPERNATURAL &raquo;</TD></TR><TR><TD CLASS="quote">i made 240+ and i knew my slicks were too big.....and those were 24.5x8.5x13</TD></TR></TABLE>
with a 4.4 final?
Old Aug 25, 2005 | 06:20 PM
Mr.boost's Avatar
Default Re: (skunked)
pre-judge the light sequence!!!! It works.
Old Aug 25, 2005 | 08:56 PM
Default Re: (Mr.boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.boost &raquo;</TD></TR><TR><TD CLASS="quote">pre-judge the light sequence!!!! It works. </TD></TR></TABLE>
How would that help? Your reaction time doesn't affect your 1/4 mile time.
Old Aug 26, 2005 | 01:19 AM
ISPhuevos's Avatar
ok guy sorry i havent reply back i went to track 8/24 i put the slicks psi at 6.5 and launch at 6700rpm(2.1 60ft 13.5@102.75) but i only one run and it have to w/ exhaust. i know the car can hit 12's, i just need more track time. Every time i go i cant run slick or i need to have an exhuast. Oh yeah i 13.9@103 w/street tire and with slick i ran 13.5@102.75 so i think the slick are not to big because im still going the speed just getting better launching. (oh and i do have 4.4final drive)
