Idling Problem '88 accord
I have a 2.0 FI 88 accord that is having issues idling. Its hopping between just above 1k to just below 2k. It wont idle normally anymore. I checked the PCV valve, and its good. I cant seem to locate a cracked/busted vaccum line, so I was wondering if anyone has any pointers?
is your coolanlt lever right? are yougetting any codes? have you cleaned your idle air controller?
check out http://www.3geez.com for more information on 3rd gen accords.
Im not sure about the coolant, I will check on that. The car is not getting hot though.
I have not tried pulling codes as of yet. I just made the assumtion that it was the PCV from what it was doing.
Nope, Im not even sure where to find the IAC, I will find it and check it though.
Thanks for the tips
Thanks for the tips
remove the cover for the fast idle valve, screwin the big black valve it has 2 slots in it turn it in till cannot go further but do not force it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warlock »</TD></TR><TR><TD CLASS="quote">Ok, IAC screw is tight as it will go to start. What do I clean the IAC with?</TD></TR></TABLE>
have u tried what i suggested?? if not do it before u dick with anything else
Honda_Civic95_Ex
Jun 19, 2006 01:47 PM
iderek
Nov 18, 2005 02:15 PM
SlackerAccord
Sep 22, 2005 08:49 PM
