Misc stuff for cheap... make offers... ef/da/eg... need it gone asap!
MAKE OFFERS! TRADES WELCOME ALSO! GET THIS STUFF OUT OF MY WAY! I CAN SEND PICS ON REQUEST. JUST PM ME WITH AN EMAIL ADDY
88-91 civic/crx
passenger air vent w/o cover
oh **** handle
shift boot plates (2)
upper "A" arms (pair)
D series upper timing cover
obd0 d series starter
obd0 d series alternator
D series flywheel cover
hf fuel rail
91 HF ecu
D series driver side mount (2)
D series rear mount bracket
92-95 civic
civic hatch oem outer tails
civic coupe/hatch jdm knockoff clear corners
civic glove box handle
stock civic/integra shifter (2)
vx heatshield
civic hatch front mudflaps
civic climate control face with ***** (2)
jdm eg6 driver side inner taillight
civic front lca's... NO holes for sway bar (pair)
vx knuckles... has the knuckle/hub/wheel studs/rotors/lower ball joints... no brakes
civic srs cable reel
civic black center console with e-brake boot... back piece only... no ashtray
civic black cupholders
civic oem shifter and ****
D series pressure plate
D series top tranny mount
92 vx srs unit... if you have only the bag in the steering wheel and no passenger bag in the dash
ex/si tranny... no 4th gear and 5th is almost gone... all other gears are fine and case is good
cx tranny... broken input shaft bearing... all gears synchros good... case is good
JDM sir2 automatic climate control WITHOUT face
90 and up teg
90-93 ls valvecover
90-93 teg headlights with bulbs... no fogs/corners/brackets
90-93 teg front calipers/rotors
90-91 ls intake manifold
90-91 ls cams
90-91 ls oem oil pump
90-91 ls water pump... aftermarket
p75 oem ls waterpump
92-93 teg driver side bumper light
94 up teg gauge cluster cover
MISC.
autometer auto gage 5" tach with shift light
jdm b16a upper exhaust mainifold with both o2 sensors
b16a heatshield
b16a2 crank gear
JDM obd0 b16a crank
B series lower timing cover
96-00 civic shift boot plate
honda "H" emblems... 1 red, 1 red w/ carbon fiber H
88-91 civic/crx
oh **** handle
hf fuel rail
91 HF ecu
92-95 civic
vx heatshield
90 and up teg
90-93 ls valvecover
90-91 ls cams
MISC.
b16a heatshield
b16a2 crank gear
JDM obd0 b16a crank
hondude87
Jul 10, 2007 07:56 PM
neutron91
Texas -OK -LA (Sales)
Aug 26, 2005 09:47 AM
