My car is throwing a code for the knock sensor, can that hurt performance?
I have a 91 civic HB, with a JDM b16a swap, with a pr3 ecu and i am getting a CEL for the knock sensor, so is having a CEL for the knock sensor hurting the performance of my car?
whenever ur cel comes on ur ECU switches over to limp mode...which i believe retards the **** out of ur timing.that alone will make u lose performance..not sure what else it does so ill let others with more knowledge to chime in...
do you think since my rex is throwing a freaking code 9 that it is in limp mode because it feels strong and vtec is working (obd1 swapped mini-me).....just curios thanx
Casey
Casey
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill »</TD></TR><TR><TD CLASS="quote">do you think since my rex is throwing a freaking code 9 that it is in limp mode because it feels strong and vtec is working (obd1 swapped mini-me).....just curios thanx
Casey</TD></TR></TABLE>
code 9 is a cyp sensor...it is in the dizzy and i do not think they make a replacement piece for it...get a new dizzy..reset ur ecu and u should be runnin good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXSI_09 »</TD></TR><TR><TD CLASS="quote">It keeps vtec from working too.</TD></TR></TABLE>
...not true to say the least.
Knock sensor cel retards ignition 2 degrees. From what I understand honda knock boards are pretty shitty at there job. Get your pr3 chipped and run a map with the KS disabled.
ok, i think i may have found the problem, i am aslo throwing a code for the IACV, so today i went to remove it to clean it and when i pulled the plug it was labeled knock, i had my harness made by rywire, the plug only had one wire running into it, a blue wire. So i figure that if i am throwing codes for a knock sensor and the IACV, and the plug for the IACV is labeled knock, that has to be my problem. I emailed ryan at rywire to see what i did wrong.
salman
Nov 18, 2008 05:27 AM
StupidSlowRSX
16
Oct 5, 2004 04:26 PM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
