Custom charge pipes!??!
Old Aug 21, 2005 | 11:15 PM
EF8 JUNKIE9's Avatar
Default Custom charge pipes!??!
Ok heres my dillema. . . just swapped the d15b in the crx, bout to boost soon. i have a greddy d series turbo kit laying in my garage waiting to be slapped on. But heres the problem i have a jdm front end on my rex and i also have FOG LIGHTS!! Now i know those foglights is going to be problem and i could see it now they're gonna get in the way. My question is, is there anyway i can get charge pipes to run around to my intercooler w/o having to get rid of my fog lights!
THANKS
Old Aug 21, 2005 | 11:27 PM
Rywire's Avatar
Default Re: Custom charge pipes!??! (EF8 JUNKIE9)
bump for him, and nice car dood!
Old Aug 22, 2005 | 06:15 AM
Turbo_Mike's Avatar
I was in the same boat, and i had to take out my foglights. My next plan is to get 90* couplers for the intercooler, and drill out huge holes through the front "crossmember" / frame to run the pipes through there. so it will resemble a backdoor style intercooler in the sense of the charge pipes.
So depending on the size of your ic, thats one route to look at.
Old Aug 22, 2005 | 06:42 AM
CRX Toad's Avatar
Nope can't do it...going to have to take the fog lights out and send them to me.
Old Aug 22, 2005 | 07:52 AM
CRX T-Si's Avatar
Default Re: Custom charge pipes!??! (CRX Toad)
Depending on how big your I/C you will be able to keep your Fog lights if you do the Back door I/C setup.
Here is a quick referrence for ya. See the end of the I/C...if have an I/C like this then you can use 2 90 degree couplers and cut 2 holes in your frame where the A/C lines goes thru. Here is a pic of the hole I am talking about, not the yellow circle....the hole has being enlarged
(Ignore the Turbo setup cause I saved this pic long time ago and forgot who this setup was belongs to)
I don't have a very good pic but here is what I got for my old setup.
See the Blue 90 degree coupler to the I/C...that goes thru the hole I mention on top. And then you would do the same for the other side.
Here is a pic of my old setup on my CRX.
I only use one 90 Degree coupler and so I was only able to keep one fog light. If I had used 2 then I would have being able to keep both of them. This is just to give you an idea.
Hope this helps you.
Old Aug 22, 2005 | 09:27 AM
Turbo_Mike's Avatar
Default Re: Custom charge pipes!??! (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">
bingo
hOW come u didnt do the same for the other side?
Old Aug 22, 2005 | 10:02 AM
CRX T-Si's Avatar
Default Re: Custom charge pipes!??! (MIKE JONES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIKE JONES &raquo;</TD></TR><TR><TD CLASS="quote">
hOW come u didnt do the same for the other side? </TD></TR></TABLE>
All the I/C piping was done by me and I didn't have that many bends thats #1, #2, I still have my Stock battery tray in the stock location so without a welder it would be most difficult to do it.
It was just easier for me at that time to just take one fog light out and run it thru the side of the fender.
Plus now....forget it....my new I/C does not allow me.
Oh yeah I forgot to mention...if you get an I/C from end to end about the length of those holes then you can actually put the I/C pipes on the other side making it a true back door I/C. So instead of having the In & out of the I/C on the sides you would have it on the back.
Old Aug 22, 2005 | 11:12 AM
CRX T-Si's Avatar
Here is an excellent Link for those that want turbo with the SiR front ends that wants to keep their Fog lights.
http://www.turbocrx.co.uk/
Just remembered that I had this in my Favorites.
Or for those with the compressor side on the driverside...here is a quick ref...I forgot who's car this was(sorry)
Old Aug 22, 2005 | 12:15 PM
^^^good info!
ok well im at work right now and ill try to post pics of how my IC works basically it goes from the right side then loops around and comes back towards the same way not the through the right side. ill post up pics later to give you guys a better view. IC is also not that big either.
Old Aug 22, 2005 | 05:14 PM
Old Aug 22, 2005 | 06:21 PM
Turbo_Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8 JUNKIE9 &raquo;</TD></TR><TR><TD CLASS="quote">^^^</TD></TR></TABLE>
wheres those pics guy?
Old Aug 22, 2005 | 06:26 PM
LoSt is BlaCk's Avatar
what about a backdoor style intercooler?
Old Aug 22, 2005 | 08:19 PM
Ok heres the pic of my IC its about 16 inches wide and 6 inches tall so you can see its really not that big.
Old Aug 22, 2005 | 09:55 PM
up up up
Old Aug 22, 2005 | 10:11 PM
Turbo_Mike's Avatar
Default Re: Custom charge pipes!??! (LoSt is BlaCk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoSt is BlaCk &raquo;</TD></TR><TR><TD CLASS="quote">what about a backdoor style intercooler?</TD></TR></TABLE>
I guess cause i dont have the extra cash to fork out for one, and sometimes they look lopsided in the grill ?
Old Aug 23, 2005 | 12:13 PM
so what do you guys think about my IC will it work?
Old Aug 23, 2005 | 12:31 PM
Turbo_Mike's Avatar
Yea...i mean anything WILL work. If thats short enough you could prolly have the inlet run into engine bay through the grill area. Then run the inlet of ic over to compressor assuming u have it on passenger side.
Old Aug 25, 2005 | 07:53 PM
any more suggestions?? you think a side mount IC would better but i wouldnt even know where to mount that either!
Old Aug 25, 2005 | 08:03 PM
Turbo_Mike's Avatar
i woudlnt mess with a sidemount, unless it was a 200 dollar d series build
Old Aug 25, 2005 | 08:52 PM
well the turbo really isnt that big, eh i dont know it was just another thought
Old Aug 25, 2005 | 09:06 PM
Turbo_Mike's Avatar
i'm sure your going to go bigger and better in the future, so i'd say to prolly start off with a decent front mount
Old Aug 25, 2005 | 09:12 PM
Mr.Death's Avatar
Here's my intercooler set up. Kinda like Mike Jones, Mike Jones![IMG][/IMG]
Old Aug 25, 2005 | 09:13 PM
Default Re: Custom charge pipes!??! (Mr.Death)
nice setup but do you have the jdm front w/ the fog lights??
Old Aug 25, 2005 | 10:05 PM
wrXtian's Avatar
where did you guys purchase that 90 degree bend coupler?
Old Aug 26, 2005 | 06:17 AM
Keith P's Avatar
Default Re: Custom charge pipes!??! (D16A6_HF)
Did some one say back door?
FS: https://honda-tech.com/zerothread?id=1341513
Good luck.
