Tail light bulbs burn out fast
Old Aug 21, 2005 | 08:20 PM
itskiLLjoy's Avatar
Default Tail light bulbs burn out fast
I bought my 96 Integra LS around the 30th of last month. About... 8 days ago, my tail/brake lights went out on my way home from work. I just assumed the bulbs were old, so I went to Autozone and bought some plain jane replacement bulbs that matched the numbers on the ones I took out. Tonight, I left work again, unlocked my car via the alarm, and saw my tail lights flash. After the 15 minute drive home, I got out and armed the alarm, taking notice that the tail lights didn't flash. I stood behind the car and locked/unlocked my car a few times to make sure it wasn't a fluke. Appears that my replacement bulbs lasted a whole damn week!
What could be causing the bulbs to burn out so fast? I have no idea how long the original bulbs lasted... but it had to of been more than 2 weeks, since I had the car that long.
Old Aug 26, 2005 | 10:32 PM
Cliffjumper2's Avatar
Default Re: Tail light bulbs burn out fast (itskiLLjoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itskiLLjoy &raquo;</TD></TR><TR><TD CLASS="quote">I bought my 96 Integra LS around the 30th of last month. About... 8 days ago, my tail/brake lights went out on my way home from work. I just assumed the bulbs were old, so I went to Autozone and bought some plain jane replacement bulbs that matched the numbers on the ones I took out. Tonight, I left work again, unlocked my car via the alarm, and saw my tail lights flash. After the 15 minute drive home, I got out and armed the alarm, taking notice that the tail lights didn't flash. I stood behind the car and locked/unlocked my car a few times to make sure it wasn't a fluke. Appears that my replacement bulbs lasted a whole damn week!
What could be causing the bulbs to burn out so fast? I have no idea how long the original bulbs lasted... but it had to of been more than 2 weeks, since I had the car that long. </TD></TR></TABLE>
perhaps a short.
did you try returning those bulbs and going with a new set?
also check your tail light wiring harness for any damage.
Old Aug 27, 2005 | 12:18 AM
DA9ReMiX's Avatar
autozone/kragen bulbs = lol..
Old Aug 27, 2005 | 01:12 AM
Spec R's Avatar
Default Re: (DA9ReMiX)
vibration is the number one killer of bulbs. its more common on work trucks, etc.
thats still odd that you went thru bulbs in a week, being that when I had my subwoofer setup in the car, i never went thru a tail bulb in years.
Old Aug 27, 2005 | 01:31 AM
Lauj87's Avatar
check if you have the right size fuse in....if its not the right size could allow too much current..not sure tho..bumbed*
Old Aug 27, 2005 | 07:54 AM
projectTeG's Avatar
are you sure your getting the right bulbs?....i had one of my fog light bulbs on my one peices keep blowing and i found out that i was getting the wrong buld.....i put the right one in it hasnt blown since
Old Aug 27, 2005 | 08:19 AM
jay_96teg's Avatar
Default Re: (projectTeG)
You may also want to check you brake light switch. This switch is located under your dash by your feet. This switch is located on a bracket so that the button is touching the brake pedal. this switch control if and when your brake lights come on by closing a circuit when the pedal is depressed. Try this..
Vagitarian
12
May 20, 2013 04:36 PM
dumafit
Northern California (Sales)
47
Oct 12, 2011 10:49 AM
ilikeric3
Aug 13, 2006 07:45 PM
tsdenny
Sep 4, 2004 10:07 AM
hobo79
13
Aug 13, 2001 05:30 PM
