$3200 is that really a good deal?
Spec C Package for 99+ Civic Si, 00+ Integra Type R - $3200
Includes the following:
Toda Spec C cams (2)
Toda Cam gears (2)
Toda Valve Springs (32)
Titanium Retainers (16)
ECU harness
ECU remapped to Spec C maps - All OBD-II is removed, rev limiter is 9500, VTEC 7200 can be tuned for any compression ratio up to 12:1.
* Note test pipe required for Spec C camshafts.
440cc Toyota injectors (new)
Free Spoon video
Free Fed Ex shipping
Toda Cam gears (2)
ECU harness
Free Spoon video
why would you buy a ECU pre=programmed, just get hondata for alot cheaper and pay someone $75 an hout to program it.
in NYC i would go to DRT in queens they can tune your car.
If you want to run Spec C cams and keep OBD2, let me know, I have an OBD2 ECU with a Spec C program in it, tuned for 11.1:1 compression. I also have the chip with the stock pregram. ECU is from my 1997 ITR #51...
Jason
Jason
maybe one of you guys could answer this, Can i just put in the spec c with springs and retainers and cam gears and be done? tune it well and not have to do anything else?
can that be, put them in, tune them and then just drive even long drives?
You can run stock compression and still make 194 whp.
As for drop them in and run, no. There is no way the stock fuel system delivers enough fuel to feed those things. I had to switch to RC310s, which the ECU is also tuned for, to get enough fuel to the injectors. I also had to switch fuel pumps. I am using the Walbro high pressure pump, a Supra TT pump would do the job well too. Then an AFPR, I suggest AEM.
These cams require some fuel. Something the stock Type-R setup cannot supply enough of...
Jason
Jason
I was thinking about it, and probably for about 3500 I could rebuild your motor
and make more power with stock cams than the stock motor with Toda cams.
I don't think is a good deal
Toda C cams $875
Toda Cam gears $280
Toda valvesprings $355
Titan retainers $220
ECU reprogram $435
ECU harness $250
Test pipe $120
Shipping $50 ?
I think the above should be decent to some ppl on this board.
Toda C cams $875
Toda Cam gears $280
ECU reprogram $435
ECU harness $250
Test pipe $120
Shipping $50 ?
Toda C cams $875
Toda Cam gears $280
ECU reprogram $435
ECU harness $250
Test pipe $120
Shipping $50 ?
Toda C cams $875
Toda Cam gears $280
ECU reprogram $435
ECU harness $250
Test pipe $120
Shipping $50 ?
"I was thinking about it, and probably for about 3500 I could rebuild your motor
and make more power with stock cams than the stock motor with Toda cams."
without divulging any secrets, how would you do this?
TypeR0149
May 1, 2002 08:57 AM
