Turbo setup what kind of Spark plugs to go with? (searched)
Old Aug 21, 2005 | 07:41 PM
Brycen's Avatar
Default Turbo setup what kind of Spark plugs to go with? (searched)
Hey guys i have been searching and searching and cannot findand answer.I actually bought a full turbonetics turbo kit from a local speed shop and i get it back Monday and was wondering what spark plugs should i use.I am currently using NGK Platinums in it with OBX 10.3mm Plug wires.Will these be good to run with that turbo setup on 7-10 PSI or should i go with others? Thnaks in advance.
Old Aug 21, 2005 | 07:48 PM
P_Adams's Avatar
Default Re: Turbo setup what kind of Spark plugs to go with? (Brycen)
You may find that you may have to go one klick cooler on the spark plug heat range if you run into detonation. NGK is still the brand to stay with
P
Old Aug 21, 2005 | 08:58 PM
goowakjai
Guest
Posts: n/a
Default Re: Turbo setup what kind of Spark plugs to go with? (P_Adams)
denso iridiums! *shrugs* i just like the name....DENSO!!!!!!!!
tundra2000
Sep 22, 2010 05:51 AM
burge
Apr 12, 2007 10:57 AM
lilintegra25
Jan 16, 2007 07:52 PM
mattEG
Sep 14, 2004 09:22 AM
