Help with timing???
Old Feb 24, 2002 | 06:34 AM
CRzex's Avatar
New User
Default Help with timing???
I just finished putting on a new timing belt everythings torqued down to specs. But when i started it up the belt makes this high pitch whining sound. It only makes the sound for a couple seconds after i start it up and when i drive it when im coming to a stop and i push down the clutch it starts making the noise again and it makes it until i do either one of 2 things, 1 start to drive again or 2 rev the engine up and it stops. Does anyone have any suggestions, i have a feeling it may be the tensioner.
Old Feb 24, 2002 | 06:49 AM
Stinkalope's Avatar
New User
Default Re: Help with timing??? (CRzex)
Are you sure it is not drive belt or belts. IF so it or they are a little loose. That is what it sounds like.
Old Feb 24, 2002 | 11:49 AM
CimorelliCRX's Avatar
Your right dude, its your tensioner, mine was doing that then my timing belt snapped. It happened about 2 weeks ago, then i fixed it, luckily nothing major happened. Good luck.
Old Feb 24, 2002 | 07:10 PM
civicwagonman's Avatar
Default Re: Help with timing??? (CimorelliCRX)
if your tensioner is too tight it will do that sometimes.
Old Feb 24, 2002 | 07:17 PM
Magick211's Avatar
Default Re: Help with timing??? (civicwagonman)
Yeop it will whine if the tensoir if over torqued steven should know about that lol
Hawkerdude
Oct 31, 2016 05:30 PM
Psycho719
Sep 14, 2011 04:28 AM
Blacktt7
Nov 28, 2007 05:12 PM
ham
Aug 2, 2005 05:17 PM
Mocky57
Feb 1, 2003 08:02 PM
