who's the CR specialist?? bojangs?
Old Feb 24, 2002 | 06:07 AM
non-VTEC's Avatar
Default who's the CR specialist?? bojangs?
i'm not to good with calculating numbers. so i need a little help.
the engine is a B20Z
84.5mm cylinder bores
Stock 3 layer headgasket
rod to stroke ratio is 1.539
46.2cc cylinder head chambers
customs JE pistions with a compression height of 1.181
dome height .120
if someone can take the time and figure out what the static CR would be in this engine i would really appreciate it. and try to be as accurate as possible if you can.
thanks
Old Feb 24, 2002 | 02:51 PM
non-VTEC's Avatar
Default Re: who's the CR specialist?? bojangs? (non-VTEC)
anyone?
Old Feb 27, 2002 | 01:20 PM
bojangs's Avatar
New User
i need the actual displacement of the piston.. unfortunately dome and compression height won't give it to me.. you'll need to cc it.. or you could try callin je and see if they know the volume.. also you'll need the deck clearance (how deep the piston sits in the hole).. i can use the stock deck clearance to give you a general idea but without the exact number the result i come up with won't be perfect..
Old Feb 27, 2002 | 01:37 PM
non-VTEC's Avatar
Default Re: who's the CR specialist?? bojangs? (bojangs)
thanks......i'll try to find out the rest of the specs.
thecruzs2007@yahoo.com
Sep 27, 2009 12:08 PM
Teamdiesel
Mar 1, 2008 08:16 PM
wm5holla
Jul 25, 2003 08:05 PM
GumballNA
Nov 6, 2002 07:47 AM
non-VTEC
Feb 27, 2002 07:59 AM
