Water leaking from rear and front AC vents (2003 Accord EX). What could be causing this?
Old Aug 21, 2005 | 12:20 PM
utgrad's Avatar
Default Water leaking from rear and front AC vents (2003 Accord EX). What could be causing this?
The rear carpet is wet and I'm assuming that something is not draining right with the AC system? Any suggesions on correcting this?
THANKS!!
Old Aug 21, 2005 | 01:01 PM
P_Adams's Avatar
Default Re: Water leaking from rear and front AC vents (2003 Accord EX). What could be causing this? (utgrad
One of the byproducts of a really efficient a/c system is water condensing on the cold a/c register. (much like the water on the outside of a cold bottle of beer).
The only place in a car where a malfunction can actually cause a problem is just in front of the glovebox where the a/c evaporator core and ductwork is located. Just like the a/c outlets, the evaporator can get so cold that large quantities of water form in the evaporator case. This normally drains out a tube (usuall visible on the outside right side of the firewall). If this tube should clog from mold or other, the water will not escape as designed and start leaking into the vehicle.
You can minimize the formation of water by condensation by operating the a/c in the "recirculation" mode. This way the a/c recools air which has already been cooled before, and you don't draw into the car outside air laden with moisture
P
Old Aug 21, 2005 | 01:51 PM
RUBZERK's Avatar
keep the ice maker on low
Old Aug 21, 2005 | 03:59 PM
YeuEmMaiMai's Avatar
clogged drain tube. like the others stated, passenger side firewall. Use a shop vac to clean it.
thekid2390
Jun 30, 2013 12:15 PM
DACteg
Jul 27, 2010 11:04 AM
No-Gi
Oct 3, 2009 06:30 AM
marrieda97accord
Jul 6, 2008 12:06 PM
plainburg
Jul 14, 2006 07:19 PM
