Neutral to 2nd question on F4i
Old Aug 21, 2005 | 09:06 AM
sup gurl's Avatar
Default Neutral to 2nd question on F4i
Okay so I was riding to church today, and I was approaching a stop light, so I just put it in neutral to coast to the light, then it turn green, but I was still going like 5-10mph so I just wanted to put it into 2nd, so I put the clutch in, and go into second and it made this really loud clank noise, I know the tranny usually clanks when you go into gear but this was pretty loud. Is this a problem? or is it normal?
Thanks
edit- haha oh ya, got my first wheelie today, couldn't resist
Old Aug 21, 2005 | 10:41 AM
jagged4698's Avatar
Default Re: Neutral to 2nd question on F4i (sup gurl)
Well on my 04 f4i i notice that when i go from nuetral to 2nd like you did it will sometimes try and "bounce out" kind of.... like the shift peg will like jump a few times and then it will go in.... i would assume thats kinda like grinding gears in a car? Am i correct? Not sure if its normal or good for the bike?
Old Aug 21, 2005 | 11:19 AM
PGK's Avatar
PGK
Prolly just the dogs engaging, it's pretty normal to get a clunk going from neutral into gear in a dogbox.
Old Aug 21, 2005 | 11:39 AM
rdblckSV650S's Avatar
Default Re: (PGK)
sounds normal to me. But i don't think you should be shifting into second at those speeds. That sounds like 1st gear material to me.
Old Aug 21, 2005 | 12:12 PM
sup gurl's Avatar
Default Re: (slvrblckf4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrblckf4i &raquo;</TD></TR><TR><TD CLASS="quote">sounds normal to me. But i don't think you should be shifting into second at those speeds. That sounds like 1st gear material to me.</TD></TR></TABLE>
I know that now, haha
Thanks for the help
Old Aug 21, 2005 | 12:16 PM
georgiajdm's Avatar
might wanna try and preload it a little....
Old Aug 21, 2005 | 12:22 PM
Newkdog's Avatar
I miss Andrea.
Gotta come on with throttle when you come off the clutch. Did you wear leathers to church?
Old Aug 21, 2005 | 12:57 PM
sup gurl's Avatar
Default Re: (Newkleus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newkleus &raquo;</TD></TR><TR><TD CLASS="quote">Did you wear leathers to church?</TD></TR></TABLE>
HAHAHA nah man, khakis and a Polo shirt under my Alter Ego Jacket
Old Aug 21, 2005 | 01:53 PM
CXHatchback's Avatar
Default Re: (georgiajdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">might wanna try and preload it a little....</TD></TR></TABLE>
+1
But under 10 you should be in first
Old Aug 21, 2005 | 02:38 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (CXHatchback)
Or just dont put it in neutral.....so that way when the car behind you doesnt see you and is coming up on you at 45mph and you're going 15, you arent just dead in the water, you can either accelerate away or speed up and swerve around the cars ahead of you and let them get rear ended. :D
Old Aug 21, 2005 | 06:34 PM
jagged4698's Avatar
Default Re: (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Or just dont put it in neutral.....so that way when the car behind you doesnt see you and is coming up on you at 45mph and you're going 15, you arent just dead in the water, you can either accelerate away or speed up and swerve around the cars ahead of you and let them get rear ended. :D</TD></TR></TABLE>
Old Aug 21, 2005 | 06:52 PM
mike5809's Avatar
Default Re: (jagged4698)
I see someone was paying attention and remembered something from the MSF course... they tought us that in ours.
good advice
i try to always keep it in first gear at lights
Old Aug 21, 2005 | 07:14 PM
sup gurl's Avatar
Yeahhhhhh I know, I took the MSF a while ago, and it was a long stretch of road and clearly saw no one behind me. Oh well. Lesson learned.
Old Aug 21, 2005 | 07:49 PM
Default Re: (sup gurl)
I'm usually coast in neutral to stoplights, but I always look behind me so I konw what's coming.
Old Aug 22, 2005 | 10:45 PM
boredracer408's Avatar
When i coast coming to a red light and it turns green before i get there i rev the motor up a lil bit and then shift to second.
This doesn't make that clanky noise when you rev the motor up...
Old Aug 23, 2005 | 06:21 AM
juicy.fn's Avatar
Default Re: (boredracer408)
yeah i never coast in neutral. i always stay in a gear till i come to a complete stop then i hit neutral if im stoped to give my little fingers the break.
Old Aug 23, 2005 | 06:59 AM
backlash's Avatar
Default Re: (juicyfn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicyfn &raquo;</TD></TR><TR><TD CLASS="quote">yeah i never coast in neutral. i always stay in a gear till i come to a complete stop then i hit neutral if im stoped to give my little fingers the break. </TD></TR></TABLE>
I do the same thing, except I only do it if I split the lanes then when I'm at the front, into neutral she goes.
Old Aug 23, 2005 | 08:54 AM
pba110's Avatar
i get the clanking either way, if i rev the engine or don't rev the engine. this is just like "grinding the gears" on a car. it's not good for the transmission. the best thing to do to prevent it is be stiff footed. if you push up gently with your foot the gears are going to ping hard...if you give it a solid upward lift, it "clunks" in pretty solid...either way, like what others have said, i recommend staying in gear and just pulling in the clutch...
TeamProjectZero
May 7, 2010 06:24 AM
ep3man
Jul 19, 2008 05:26 PM
PNB
Honda S2000
Aug 20, 2004 02:42 PM
stripes777
Honda Motorcycles
12
Jan 4, 2004 06:57 PM
Turtle
Mar 19, 2003 01:57 PM
