Overrevved, very slight rough idle now.
Ok this happened about a week ago or so. I was getting on it, was going into 4th, and it slipped and went into 2nd for a split second. I pushed in the clutch right away, it was for more than a second at the most. I have a fully built head w/ portflow springs/retainers, ss valves. Ok so the car drives perfectly fine, i've done a compression test, that came out perfect straight across the board at 210 per cylinder, 208 on one of em.
I'm pretty it didn't bend it a valve, might have however, don't know. But the issue i'm having is the idle is just a tad bit rough, i really only notice it cuz it feels a bit rougher with my hand on the steering wheel. You can notice a bit difference in sound. I have a vid i'll be posting up here in a few mins. I'm thinkin it might just need a valve adjustment, the only sympton i have to a bent valve is the idle, and its not even really bad. Just seeing if you guys can lend any help.
i did almost the same thing in our gsr...im not sure about your built head but it doesnt take much to float the valves on a stock motor..hopefully your valves arent bent but thats exaxtly the symtoms i had.
i'm not sure, it tached out, i'm not really 100% sure if it went into 2nd or back into 3rd, cuz my hand slipped off the shifter, but if it went into 3rd then it should have really bent a valve or had any effect i would think. I went to shift at around 8200 or so.
heres the vid, listen to sound of the exhaust.
http://www.jtheory.net/vids/idle.wmv
Ya well obviously, i know that. I just wanna see first if anybody can tell from experience by the sound, etc..., i'm going to have a valve adjustment done before anything, then if theres still an issue then prob gonna have to pull the head and check out the valves.
I didn't watch the video, (56k owns me), but from the symptoms I think you might be alright with just a valve adjustment. With bent valves it would probably be idling alot rougher than how you describe it.
****, i think i might have the same problem, i have a LS motor with a chipped ECU and i might of taken it over 7.2 k rpm too much, my idle is fucked up like urs but worst, it sometimes goes down to 100 and feels lke its going to shut off , do u think i might of done something?
i over-revved twice in my GS-R but not because of mis-shifting, because i wasnt paying attention to my rpms until the rev-limiter kicked in.....my idle isnt rough but my exhaust backfires every 5-10 seconds while idleing....wonder if its the same problem
To bring this thread back, i've got an update on my situation. We've done a leakdown test and everything is perfectly fine, doesn't look to be any bent valves, compression test came out straight across.
Got the valve adjustment done, runs a bit smoother, not really an idling issue with the car not idleing at the right rpm, it sounds almost as if its not running 100%. My dizzy has been giving me issues for a while, and it might have been on its last legs, so I have a new one on order, so i'm thinkin that'll take care of it. If you watch the video you can hear what i mean about how it sounds.
i came really close to that the other day..was WOT at 8200 and went to shift into 5th but accidentily hit 3rd luckily i only let the clutch out a little bit before i noticed what i did and i quickly put the clutch back in right when the RPMs were crossing the 6k mark from the mis shift...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSP-DC2 »</TD></TR><TR><TD CLASS="quote">that wouldnt of mattered TOO much honestly.... (1997 gsr) </TD></TR></TABLE>
i'm pretty sure that completely shifting from 4th at 8200 into 3rd instead of 5th would screw something up
i was just lucky enough to catch the RPM at 6k while it was on its way up to be way past 8200 if i didnt push in the clutch when i did
I dunno, i know theres somethin wrong, compression & leakdown test came out good. So i'm not really sure, i mean if it was a bent valve the leakdown test should've shown somethin right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warrick »</TD></TR><TR><TD CLASS="quote">maybe the timing belt skipped a tooth.</TD></TR></TABLE>
not to flame or anything....i just dont understand how people mis-shift going into 4th.
It sounds like a misfire. What year is your GSR? Are there any CELs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Have you looked at your spark plugs?</TD></TR></TABLE>
I'd also look at the distributor cap and rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BucsJosh »</TD></TR><TR><TD CLASS="quote">My dizzy has been giving me issues for a while, and it might have been on its last legs, so I have a new one on order, so i'm thinkin that'll take care of it. If you watch the video you can hear what i mean about how it sounds.</TD></TR></TABLE>
This is probably the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">It sounds like a misfire. What year is your GSR? Are there any CELs?
I'd also look at the distributor cap and rotor.</TD></TR></TABLE>
the the newer dc model have the little screw on the rottor that comes off once in awhile....like the DA's?
