Cracked sleeve - need input ASAP
Old Aug 21, 2005 | 06:36 AM
sykotic's Avatar
Default Cracked sleeve - need input ASAP
Ok guys I need some input pretty quickly, I cracked 1 of the sleeves on my b18b1 at the track on friday, I thought it was a headgasket but turned out to be the sleeve. I ran the car too many times without letting it cool down and I guess it just eventually overheated. Anyway, I need to figure out what to do. I start school the 29th of this month and I need a car for work so the fastest way I can get this thing running is what I want.
Can a sleeve be repaired? The crack is about 2.5"-3" down the sleeve. How costly is this, will I need a re-ring kit if I pull this apart to have it repaired?
Anyone know where I can buy a bare block or just the complete bottom end already assembled, or hell maybe even the entire motor(no tranny or accessories). I can't do a search because the search server is down or else I'd try to find a block/engine on here and search for sleeve repair. Throw out some suggestions, I have a little bit of $$$ in reserve for tuition next month but I'm sure I can put it back if I have to spend it to fix the car. I have a full k24a4 long block sitting in my garage that I would love to swap in but at this point I don't think that's going to be possible, so if you know any place that may consider trading me a b18b1 for my k24a4 then I am all ears, or if you know anyone that will buy my k24a4.
Old Aug 21, 2005 | 07:27 AM
dcb16's Avatar
Default Re: Cracked sleeve - need input ASAP (sykotic)
just get a b18 bottom end, they are dirt cheap
Old Aug 21, 2005 | 09:13 AM
sykotic's Avatar
Default Re: Cracked sleeve - need input ASAP (dcb16)
problem is finding one and getting it before next weekend though =/.
Old Aug 21, 2005 | 09:27 AM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotic &raquo;</TD></TR><TR><TD CLASS="quote">problem is finding one and getting it before next weekend though =/.</TD></TR></TABLE>
i cracked the sleeves on cylinder 2 and 3 last weekend, already picked up another motor, bc I just dont have cash to sleeve it at this moment. Just look around, and make sure you post on here, a bunch of deals came my way
fika84
Mar 18, 2005 07:10 AM
sikciv666
Jul 6, 2004 06:06 PM
DamonBoost
Apr 8, 2002 09:43 AM
