Need Honda Accord 98 driver side mirror
Old Aug 21, 2005 | 05:41 AM
yasir4u's Avatar
Default Need Honda Accord 98 driver side mirror
anyone who has one plzz lemme know or anywhere i can get a good deal ... i am in toronto canada
Old Aug 21, 2005 | 07:21 AM
Future.'s Avatar
Default Re: Need Honda Accord 98 driver side mirror (yasir4u)
You should try the classifieds.
Old Aug 21, 2005 | 08:59 AM
P_Adams's Avatar
Try these guys, I've bought from them several times.
http://www.1aauto.com/1A/Mirrors/Honda/Accord
P
Old Aug 22, 2005 | 01:04 AM
Heat's Avatar
You'll need to know which color, use the exterior color code on the sticker on the inside of your driver's door, the mirror comes from the factory pre-painted.
For my '99 I've replaced both mirrors, one about 5 years ago and one this past spring. It's a relatively easy replacement, the only part that took a little time was removing (then replacing) the door panel.
MSRP on a '99 mirror was ~ US$200, but the '99 is a "bendable" mirror while the '98 is a fixed mirror* so the '98 might be a little cheaper. Anyway, you can buy them at about 20% or 25% off from online stores. I have no idea what the going rate for these mirrors is at a junkyard, but if you go this route make sure you know what the color code for your car is and get a mirror from the same color car.
* The way to quickly tell the difference between a '98 and '99 is to look at the side mirror, if you see a black line (from where the mirror bends), it's a '99. If you look in the back dash and see tether mounts but everything else is the same, it's an '00.
Importn2oRacer
Nov 20, 2023 06:07 AM
stargazer
Apr 30, 2010 06:32 PM
jim109
Dec 19, 2007 08:59 AM
YeuEmMaiMai
Jan 4, 2006 08:20 PM
convict
Apr 22, 2003 10:22 AM
