What does boost feel like???
Old Aug 20, 2005 | 11:13 PM
DreamCatcher's Avatar
Default What does boost feel like???
Really, how does the driveability of boost compare to an all motor engine with the same amount of hp?
I know throwing a turbo is cheaper and smarter but the application of power matters as well. I'm thinkin of swapping fo' powr, damn options.....
Please dont start a flame war.....
Old Aug 20, 2005 | 11:30 PM
tony n.'s Avatar
Default Re: What does boost feel like??? (DreamCatcher)
boost....is fun
Old Aug 20, 2005 | 11:37 PM
quik sol's Avatar
Default Re: What does boost feel like??? (boosted2cam)
it's a rush....ya nail the gas, ya hear the turbo start to spool, it gets louder psi by psi as it climbs, shift, blow off valve goes off, get pulled back in your seat....
its just awesome
Old Aug 20, 2005 | 11:38 PM
jdm'dc2sc61's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DreamCatcher &raquo;</TD></TR><TR><TD CLASS="quote">Really, how does the driveability of boost compare to an all motor engine with the same amount of hp?
Please dont start a flame war.....</TD></TR></TABLE>
turbo is not cheap, it's lotta maintenance. you can't just slap on a turbo kit and expect things to run perfectly. but hey, if you dont care how long your car lasts, go for the turbo
Old Aug 21, 2005 | 12:03 AM
raene's Avatar
Driveability depends on turbo size. Go with a T67 on a B16 and you'll have problems with that aspect... go with a .48 a/r T3/T04E and it will spool and carry nicely throughout the band. It all depends on turbo sizing.
Old Aug 21, 2005 | 12:13 AM
SOHCEK-Turbo's Avatar
Default Re: What does boost feel like??? (jdmzintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmzintegra &raquo;</TD></TR><TR><TD CLASS="quote">
turbo is not cheap, it's lotta maintenance. you can't just slap on a turbo kit and expect things to run perfectly. but hey, if you dont care how long your car lasts, go for the turbo </TD></TR></TABLE>
Turbo is not a lot of maintenance if done right the first time. Ive had mine installed for over 2 months without a problem. Of course I dont slam on the gas every time. I try not to hit boost at all most of the time. But every engine is different some will have problems with boost and some wont.
Booost
Old Aug 21, 2005 | 12:14 AM
Type-X's Avatar
Default Re: What does boost feel like??? (raene)
compare dyno charts. I've been doing this and most turbos have more tourque than some N/A motors even when they hit the same whp
Old Aug 21, 2005 | 12:38 AM
CrazyHarry's Avatar
Default Re: What does boost feel like??? (quik sol)
feels good!
Modified by CrazyHarry at 8:53 PM 8/30/2005
Old Aug 21, 2005 | 01:01 AM
Default Re: What does boost feel like??? (CrazyHarry)
You guys make it sound like so much fun , but why am I attracted to a difficult b18c swap in my crx??? I know I'll end up with a turbo, but if price and all other baddies weren't an issue would you drop a b18c in a rex, that motor has the numbers I want.......I currently have a flawless sohc zc-- non vtec, I want around 185hp, dont want to sacrifice my already limited low end... Options make being an H car owner difficult.
Old Aug 21, 2005 | 06:14 AM
LostCRX's Avatar
that's not neccessary true. If it was done right with the right stuffs, with a good tune then it will run for a very long time. Regardless what you do to the car, all Motor of Turbo, if you try to cheap out or don't know what you're doing, you will have a lot of problems.
Boost is fun though, especially when you get pulled into your seat when the boost kicked in!
Old Aug 21, 2005 | 06:53 AM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DreamCatcher &raquo;</TD></TR><TR><TD CLASS="quote">You guys make it sound like so much fun , but why am I attracted to a difficult b18c swap in my crx??? I know I'll end up with a turbo, but if price and all other baddies weren't an issue would you drop a b18c in a rex, that motor has the numbers I want.......I currently have a flawless sohc zc-- non vtec, I want around 185hp, dont want to sacrifice my already limited low end... Options make being an H car owner difficult.</TD></TR></TABLE>
if you only want 185whp, I wouldnt swap. You can do that easily on a D series.
Old Aug 21, 2005 | 07:06 AM
rpm11's Avatar
Boost is like Heroin. Soooooo Good.
Old Aug 21, 2005 | 07:11 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: What does boost feel like??? (rpm11)
boost feels like crack
Old Aug 21, 2005 | 07:12 AM
Jwbetley's Avatar
If you have a rex, just buy a b18a. That would be your best bet. Better low end torque than most honda engines, and pretty potent stock turbo motor.
Check this out.
<A HREF="https://honda-tech.com/zerothread?id=1323059
" TARGET="_blank">https://honda-tech.com/zerothread?id=1323059
</A>
LS-T's have made many people, including myself, happy with the results. I think it's the cheapest way to go really fast, if you do it right.
research
Old Aug 21, 2005 | 07:23 AM
94lsboost's Avatar
Default Re: What does boost feel like??? (Jwbetley)
It feels almost like having sex with hot triplets while you are watching sportscenter and their mom is cooking you dinner...
almost.
Old Aug 21, 2005 | 09:28 AM
Default Re: What does boost feel like??? (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">if you only want 185whp, I wouldnt swap. You can do that easily on a D series. </TD></TR></TABLE>
Yeah...I kind of have to keep this engine.... Which turbo would give me the 185hp I'm looking for??? I know that there are several variables, but just to shoot the ****, what would you do to reach 185&gt;
Old Aug 21, 2005 | 10:54 AM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: (my si is bluer than yours)
exponential acceleration. thats what it is
Old Aug 21, 2005 | 11:06 AM
LostCRX's Avatar
I wouldn't never buy a kit, piece one together is much more rewarding and gives you a better understanding of things. Any fool can buy a kit and slap it on.
Modified by LostCRX at 3:09 PM 8/21/2005
Old Aug 21, 2005 | 11:14 AM
93supercoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpm11 &raquo;</TD></TR><TR><TD CLASS="quote">Boost is like Heroin. Soooooo Good. </TD></TR></TABLE>
Fat bundles
Old Aug 21, 2005 | 11:23 AM
epic1si's Avatar
boost is like warm apple pie.....
Old Aug 21, 2005 | 11:55 AM
Default Re: What does boost feel like??? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">boost feels like crack</TD></TR></TABLE>
Lemme getta straight.
Old Aug 21, 2005 | 11:59 AM
Default Re: (LostCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostCRX &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't never buy a kit, piece together one is much more rewarding and give you a better understanding of things. Any fool can buy a kit and slap it on.</TD></TR></TABLE>
A kit is a start for some people and if you get a greddy kit they are under $1400 which is what I got mine for. I didnt know **** about turbos until I installed the kit myself, now I know what kind of turbo to build next time. 185whp is easy on a Greddy kit just add on some DSM 450s and use Crome or Uber.
Old Aug 21, 2005 | 12:12 PM
specv5150's Avatar
Default Re: (EK-TSOHCV-TaKRider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-TSOHCV-TaKRider &raquo;</TD></TR><TR><TD CLASS="quote">
I did the same. If you are brand new and have no one who has done if before you to help you through it, just buy a kit.
Old Aug 21, 2005 | 12:50 PM
PA MATT's Avatar
Default Re: (specv5150)
I did the same. If you are brand new and have no one who has done if before you to help you through it, just buy a kit.</TD></TR></TABLE>
I also agree. The greddy kit was a great learning experience. Pretty good power and everything went together really well. If I did it over again, my first turbo setup would be a complete kit again
Old Aug 21, 2005 | 04:18 PM
a1320addict's Avatar
Default Re: (PA MATT)
boost is like sex....excepts it never ends...you can keep going and going and going....
