t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1
Old Aug 20, 2005 | 06:15 PM
11SEC CIV's Avatar
Default t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1
Any insight on any of these turbo's..Im looking for a new turbo but it must be a t4 flange...im basically looking for the qwikest spooling turbo thats capable of 550whp
Old Aug 20, 2005 | 06:29 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1 (12SEC CIV)
quik spooling and t4 dont go together. besides the turbos you have listed are too varied.
a to4e will only support 480crank hp
Old Aug 20, 2005 | 06:42 PM
non-VTEC's Avatar
why not look into a full-race t3/t67
everyone seems to love those things........
Old Aug 20, 2005 | 06:44 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1 (non-VTEC)
i say you talk to TheShodan, he can help you out with any turbo questions you may have and can recommend a turbo just for your application
Old Aug 20, 2005 | 06:50 PM
11SEC CIV's Avatar
Default Re: t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1 (wantboost)
i need a t4--thanks. i will
Old Aug 20, 2005 | 07:01 PM
wantboost's Avatar
Who is Mr Robot?
yea, tell him i sent you. he's a really knowledgeable guy and pretty much knows everything about garrett turobs
Old Aug 20, 2005 | 07:18 PM
11SEC CIV's Avatar
cool thanks, I know it sucks but really dont have another choice other then t4
so any input would appreciated--thanks
Old Aug 20, 2005 | 07:26 PM
wantboost's Avatar
Who is Mr Robot?
why not? what manifold do you have.
Old Aug 20, 2005 | 07:32 PM
PeakBoost's Avatar
B*A*N*N*E*D
just to clarify, the t67 is the same exact compressor as the to4R and the gt40 compressor section being used is the 56 trim 61mm wheel that is used on the gt35r and sc61.
pm me with any other questions
ken
Old Aug 20, 2005 | 08:23 PM
11SEC CIV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">why not? what manifold do you have.</TD></TR></TABLE>
t4 full-race
anyinfo on the t4 gt35r??
whats the min .ar???
Old Aug 20, 2005 | 08:52 PM
PeakBoost's Avatar
B*A*N*N*E*D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">
whats the min .ar???</TD></TR></TABLE>
we offer it with a .58, .70, .84, .96, 1.00, 1.15 and 1.32 a/r's for the T4 frame turbos with options from o-trim to GT-S.
the compressor uses a .70 a/r with the 56 trim gt35R wheel.
ken
Old Aug 21, 2005 | 06:05 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">quik spooling and t4 dont go together. besides the turbos you have listed are too varied.
a to4e will only support 480crank hp</TD></TR></TABLE>
I'd have to concur here.. You'll need to be a bit more specific in terms of the purpose of the car. All of those particular applications that you listed are extremely varied.
Ken@ PheonixTurbo gave you many of the specifications that are available for all three, the question is what WHAT your engine application is, where you want the powerband, type of power, etc. Just saying Quick spooling and T4 Flange is almost an OXYMORON. Expect to spend about a grand or so as well.
Old Aug 21, 2005 | 06:27 AM
wantboost's Avatar
Who is Mr Robot?
t4 full-race
send it back to full-race, im pretty sure geoff would have someone re-weld a t3 flange on
Old Aug 21, 2005 | 07:29 AM
Justin Olson's Avatar
The way the collectors are cut on the t4 manifolds, it wouldn't work to just cut off the t4 flange and weld a t3 flange on. the rectangle formed by the 4 tubes comming together is the same size as the t4 flange opening. If you welded on a t3 flange there would be some overlap and the collector wouldn't operate properly.
If I were you I'd get a pt61 with a stage 5 turbine wheel. That would spool almost as fast as a sc61, but with the t4 footprint you are looking for.
Justin
Old Aug 21, 2005 | 08:18 AM
timg's Avatar
Qucikest spooling turbo for 550 whp...
How about a GT35R? They're available through a few vendors (like atpturbo.com) with a T4 turbine housing. That should spool very quickly and still be capable of your power goals.
Tim
Old Aug 21, 2005 | 08:49 AM
11SEC CIV's Avatar
I have already talked to the guys at full-race and they are being more then helpful its just the turn around time doesnt allow me to race this year. .
I understand qwick spool and t4 dont go together, but what i want is the qwickest spooling t4 from the turbos i mentioned..I really dont know specifics w/ ar's thats why im asking for help...
my goals are to reach 450 whp but the turbo capable of making more
i'd like to see full boost no later then 5500. My engine is 81.5mm gsr
w/ money not being an factor, does this info help?
Old Aug 21, 2005 | 08:52 AM
boosted92's Avatar
With money not being a factor sell the T4 manifold, buy a T3 manifold, and buy a T3/GT35R because none of those turbos are going to be making serious boost by 5500.
Old Aug 21, 2005 | 08:55 AM
11SEC CIV's Avatar
Default Re: t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1 (boosted92)
https://honda-tech.com/zerothread?id=1342193
im tyring but not looking too good
Old Aug 21, 2005 | 09:11 AM
speeddave's Avatar
from my understanding the t04s 60-1 w/a .58exh will spool sooner than the t4/t4r or the gt40. they are much larger turbo's. the precision pt-61 is also i think in between the 60-1 and the larger t4/67's. it should spool sooner than the bigger turbo's, maybe a bit later than the 60-1 but it is rated for 680hp.
Old Aug 21, 2005 | 03:12 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1 (speeddave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeddave &raquo;</TD></TR><TR><TD CLASS="quote">from my understanding the t04s 60-1 w/a .58exh will spool sooner than the t4/t4r or the gt40. they are much larger turbo's. the precision pt-61 is also i think in between the 60-1 and the larger t4/67's. it should spool sooner than the bigger turbo's, maybe a bit later than the 60-1 but it is rated for 680hp.
from above, in case anyone missed it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoenixturbo.com &raquo;</TD></TR><TR><TD CLASS="quote">just to clarify, the t67 is the same exact compressor as the to4R and the gt40 compressor section being used is the 56 trim 61mm wheel that is used on the gt35r and sc61.
ken
imho, the t4/gt40 with a .58 a/r and an o-trim wheel will be your best choice for reaching your desired spool characteristics and is supportable of ~550whp.
with the gt series wheel being lighter weight and having 6 not 7 blades, it will spool slightly quicker than the 60-1 with the same turbine section.
hth
ken
Old Aug 21, 2005 | 03:20 PM
speeddave's Avatar
Default Re: t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1 (PhoenixTurbo.com)
as far as affordability wise, would the t04s 60-1 be a comparable match to the t4/gt40 o-trim combo? it would support about the same hp, but at how much of a later spool? thanks.
edit: so then is what i said wrong? would the pt-61 or your t4blowzilla, spool quicker than the 60-1?
thanks ken
Old Aug 21, 2005 | 04:17 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">I have already talked to the guys at full-race and they are being more then helpful its just the turn around time doesnt allow me to race this year. .
w/ money not being an factor, does this info help?</TD></TR></TABLE>
This information does help, but the expectation is not realistic due to the lack of FULL displacement (both bore & stroke) of that GS-R motor. Even the GT40R can't solve that problem that easily. We're not asking about what A/R you think you should get (that is why you're asking, right?). What we're asking is the PURPOSE of the setup. A/Rs are only the beginning of creating characteristics, not the end.
I can assist w/ what you need, and can get it available for you as well. I'll be answering your PM sometime this evening.
Old Aug 21, 2005 | 05:16 PM
11SEC CIV's Avatar
Default Re: t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1 (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">I can assist w/ what you need, and can get it available for you as well. I'll be answering your PM sometime this evening.</TD></TR></TABLE>
thanks for your help
Old Aug 22, 2005 | 01:01 PM
Turbocivic94's Avatar
I have ken's .58 a/r T04/T04R on my 2 liter gsr. I'm running 11lbs and reaching full boost around 5000 rpm. I would recommend phoenixturbo.com cause ken's customer service is the best. He would go the extra mile to help his customers. I hope this helps
Old Aug 22, 2005 | 01:06 PM
11SEC CIV's Avatar
Default Re: t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1 (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">I have ken's .58 a/r T04/T04R on my 2 liter gsr. I'm running 11lbs and reaching full boost around 5000 rpm. I would recommend phoenixturbo.com cause ken's customer service is the best. He would go the extra mile to help his customers. I hope this helps</TD></TR></TABLE>
I pmd him, just waiting to hear back...he def seems top notch
