more tranny fluid questions
Old Aug 20, 2005 | 02:56 PM
97akwerd's Avatar
Default more tranny fluid questions
I have a tranny cooler on my car do I need extra fluid to make up for it, or just stick to the levels on the dipstick? It was like maybe 1 X short of the top when I checked it after I left the car running for 4 min and backed it into my driveway.
I added like 100ml of fluid and now its up to the last X...Is it possible for that little amount I added to make that difference?
Should I keep it over fill? Since I have the tranny cooler, or really no difference? I read some places the tranny runs better overfill, and then I see somethings say its worse, because it can't cool as well when their is too much.
When I check the tranny fluid cold its overfill, but after its running for 3-5 min and I back it into my driveway the level is right at the top X.
Old Aug 20, 2005 | 03:54 PM
sauceja's Avatar
Default Re: more tranny fluid questions (97akwerd)
Check tranny fluid at running temp. Honda does not require engine to be running to check level. So wait about 1 minute after shutting car off to check.
DO NOT OVERFILL unless you want to start replacing seals or worse.
Top line is good, a little less is better than a little more.
Please use only Honda ATF and do your car a favor.
Old Aug 21, 2005 | 10:24 AM
97akwerd's Avatar
Default Re: more tranny fluid questions (sauceja)
bump
Old Aug 21, 2005 | 02:20 PM
sauceja's Avatar
Bump for you again.
About the tranny cooler. Fluid will be in the cooler and tranny. So the line is good either way.
Also if this is a 5-sp and you have a tranny cooler to it then use only Honda manual tranny fluid. It may cost a little more the auto **** I mean zone. But at least you are still doing your car the best favor you can.
I still recommend Honda fluid for all things. Coolant, brake, power steering, tranny, even the filters. Oil too but that is not as big of a deal as long as you stay away from Pennzoil.
97akwerd
Jul 29, 2005 11:50 AM
95gsrturbo
Acura TL, RL & ZDX
Apr 9, 2005 09:07 PM
B2FiNiTY
Oct 30, 2002 05:50 AM
mrnicolas
Oct 9, 2002 10:52 AM
01-1293
Jul 9, 2002 08:34 PM
