car not starting...kind of strange
Old Aug 20, 2005 | 02:36 PM
whitelightning's Avatar
Default car not starting...kind of strange
b18c1 in 96 civ
it cranks but won't turn, i'm not getting any spark. new cap,rotor ignitor plugs, wires. coil checked out okay vs helms.
main relay also checked out okay.
i'll turn the ignition, and just cranks away. when i pull the key out the dash lights stay lit!! its like i never pulled the key out. it will shut off once i pull the alt fuse from under dash or pull the battery cable off the terminal.
any ideas, i am at a lost.
Old Aug 20, 2005 | 02:58 PM
hybrid racing's Avatar
So you are using an OBD2 engine harness and OBD2 distributor?
I would try to swap out your dizzy with a buddies.
Old Aug 20, 2005 | 08:43 PM
ek99's Avatar
Default Re: (hybrid racing)
Did you look to see if your harness ground is connected? Sounds like some kind of electrical problem.
Old Aug 21, 2005 | 10:50 AM
Default Re: (ek99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 &raquo;</TD></TR><TR><TD CLASS="quote">Did you look to see if your harness ground is connected? Sounds like some kind of electrical problem. </TD></TR></TABLE>
i checked the motor ground, tranny ground, starter ground, therm ground, alternator...i'll check the harness, but i'm certain its grounded....i'll let ya know the status.
Old Aug 31, 2005 | 11:26 AM
Default Re: (whitelightning)
bump
Old Aug 31, 2005 | 04:46 PM
Dragline's Avatar
Try unplugging the 4 wire plug from your alt. and see what happens.
Old Oct 1, 2005 | 03:29 PM
Default Re: (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">Try unplugging the 4 wire plug from your alt. and see what happens.</TD></TR></TABLE>
i pulled the alternator plug and the dash light remains on...the buzz i hear around the injectors remain as well...help!!!!!!!!!
brandonEM1
Jan 23, 2013 08:06 PM
98bucket
Aug 3, 2011 07:58 PM
|jdm Mike|
Mar 15, 2010 12:11 PM
mike03,95civic
Dec 31, 2008 08:11 AM
hondacrxsiguy
Jan 2, 2008 04:15 PM
