Transmission question
Old Feb 23, 2002 | 09:36 PM
RexB16's Avatar
Default Transmission question
i figure i will try here as well. any of you happen to know if a 88-91 Si tranny will bot up to an 89 integra? i know they are both d series motors, but i know that the usdm zc in the integra is slightly different than the jdm zc (on which an Si tranny does work)
thanks
Old Feb 24, 2002 | 05:33 AM
HondaCutie90's Avatar
Default Re: Transmission question (RexB16)
there's no such thing as a "usdm zc", it's a d16a1.
regarding the tranny, i don't it'd work because the mounts are different. but don't quote me...send a message to Mista Bone, he's the dseries tranny guru here.
Old Feb 24, 2002 | 09:30 AM
-TJ's Avatar
-TJ
Default Re: Transmission question (HondaCutie90)
Engine mounts be damned, that wasn't the question... Yes, an L3 tranny will bolt up to a D16A1 (86-89 integra) block. During a H-parts re-organization in my garage, I tried sticking an empty L3 case onto my bare D16A1 block.
Now, yes the L3 tranny has a different tranny housing casting for the EF mount system. It's as if Honda just recycled the original CG (integra) clutch housing and cast a new tranny housing for the EF's and called it an L3.
The internal's of a CG tranny are vastly different from an L3 though...no swapping there.
Old Feb 25, 2002 | 07:31 AM
RexB16's Avatar
yes there is, i dunno if thats what honda calls it, but its a zc that was sold in america with a different output than what it had in japan, so that to me is usdm. ao TJm ur saying that it will bolt up but the internals are different?
Old Feb 25, 2002 | 08:34 AM
MrFatBooty's Avatar
Sure, the D16A1 is basically a ZC internally. Except that nowhere on it is anything resembling ZC stamped on it. Plus the D16A1 has a mounting scheme like the 84-87 Civic and the ZC is designed to bolt into EF's and such.
Old Feb 25, 2002 | 12:35 PM
-TJ's Avatar
-TJ
Default Re: Transmission question (MrFatBooty)
Yes. An L3 will bolt to a D16A1. Amen. You are on your own for a tranny mount but it bolts to the motor.
I'm not exactly sure what flywheel/clutch pressure plate you'd use because I only bolted the empty L3 case to the bare D16A1 block.
Old Feb 25, 2002 | 12:39 PM
RexB16's Avatar
Default Re: Transmission question (-TJ)
hmm good point about the clutch combo, i ahve no idea what would work. i guess as far the a tranny mount i could tap the case if worst came to worse, they are aluminum right?
Old Feb 25, 2002 | 12:44 PM
-TJ's Avatar
-TJ
Yeah, they are aluminum, but in any location other than where there is already threaded holes, it wouldn't be a good idea to tap threads. The case walls aren't that thick - you'll end up poking a new drain hole. A mount could certianly be fab'd using the old mounting location (under the frame rail) and the top of the L3.
Old Feb 25, 2002 | 09:54 PM
RexB16's Avatar
heh, or maybe i can quit being such i cheap bastard and go get a teg tranny. yo KNOW its bad whe your backup car starts to fail on you.
sohcvtec91hatch
Aug 13, 2006 06:08 PM
temp
21
Jul 30, 2004 05:43 PM
00WhiteEKy
Apr 2, 2004 09:01 AM
sloweredcivic
Oct 16, 2003 03:27 AM
UNDER PRESSURE
Jun 5, 2003 09:15 AM
