Does anyone have the specs for the Skunk2 Pro2+ cams?
Old Aug 20, 2005 | 01:49 PM
VTECJUN's Avatar
Default Does anyone have the specs for the Skunk2 Pro2+ cams?
Does anyone have the specs for the Skunk2 Pro2+ cams? I need to degree them in my new setup but I have no specs. Any help would be appreciated. Thanks
Old Aug 20, 2005 | 04:43 PM
IN VTEC's Avatar
Default Re: Does anyone have the specs for the Skunk2 Pro2+ cams? (VTECJUN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">The Skunk Pro2 spec sheet is 270 dur@1mm 12.8 lift 98 ctr line IN. 276 dur@1mm 12mm lift 104 ctr. line EX.</TD></TR></TABLE>
You can calculate the opening and closing angles from that, or just degree them in using the centerline.
Old Aug 20, 2005 | 06:49 PM
DonF's Avatar
Default Re: Does anyone have the specs for the Skunk2 Pro2+ cams? (IN VTEC)
The opening at 1mm 37BTDC closing 53 ABDC IN. EX. opening at 1mm 62 BBDC closing 34 ATDC these are .000 lash. I got a few degrees less at the valve so just split the diff. 35 open and 51 closing is still 98 centerline on the intake. Stick with 98 in 104 EX. and you will be fine.
Old Aug 21, 2005 | 10:22 PM
VTECJUN's Avatar
Default Re: Does anyone have the specs for the Skunk2 Pro2+ cams? (DonF)
Thanks. I am using these in a new motor and i couldnt find the center line specs. I think I am good to go now. Hopefully these will work out for me.
Old Aug 25, 2005 | 08:30 AM
ptoledo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECJUN &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have the specs for the Skunk2 Pro2+ cams? </TD></TR></TABLE>
Not sure if you found em yet...
http://www.hybrid-performance....2.pdf
Old Aug 25, 2005 | 10:00 AM
VTECJUN's Avatar
Thanks!
itr_henrik
Dec 4, 2007 06:50 PM
4dooritr
Mar 25, 2007 07:02 AM
b20vtech
16
Oct 19, 2006 07:59 AM
paulITR
May 14, 2006 10:27 PM
veilsides2000
Jul 26, 2005 06:30 AM
