Not leaving for USMC yet, so working on installing gauges.
Old Aug 20, 2005 | 01:49 PM
USMCAccord's Avatar
Default Not leaving for USMC yet, so working on installing gauges.
I have a Oil PSI Gauge, and a Water Temp gauge that I need installed. I own a 94 two door accord, equiped with an H22, not sure what year it is. Looks like all the other h22s that are installed. I had some work done to it but it wouldn't compromise the location of the water temp sending unit. I can't find this damn thing as I never really play with anything under the hood anymore. Can anyone provide me a picture of the sending unit and wiring for the h22 ? Would be great, I tried using the search function but its been down for some time, thanks.
Old Aug 20, 2005 | 02:24 PM
P_Adams's Avatar
Default Re: Not leaving for USMC yet, so working on installing gauges. (USMCAccord)
So, the last go around worked out so well (brake light switch et al) that you decided to play with it some more, Eh?
Are these electrical or mechanical gauges?
Let me see if I can scare something up
P
Old Aug 20, 2005 | 03:21 PM
USMCAccord's Avatar
Default Re: Not leaving for USMC yet, so working on installing gauges. (P_Adams)
Electrical, I just need the location of the sending units for the Oil PSI and Water Temp. Ya, brake lights worked out great
Old Aug 20, 2005 | 07:06 PM
P_Adams's Avatar
Here's a link to an illustration of where your temp sensor is located, Unfortunately, Honda doesn't properly id them (sorry)!!!!
http://www.hondaautomotivepart...OSTAT
I'm still looking for the %$^#*&^ Oil PSI sensor..........
P
Old Aug 20, 2005 | 09:07 PM
USMCAccord's Avatar
Update. Water Temp was easy, oil PSI Sending unit is directly below the oil filter. Easy deal, the sending unit I had to put in fit perfectly, however, putting in new oil filters will be a tad tricky Thanks for your help P.
sle3py_se3z
Sep 20, 2010 06:25 AM
whitediamond642
Feb 7, 2008 12:03 PM
machine4321
Jun 13, 2006 02:55 PM
hatchinprogress
Dec 16, 2005 04:14 PM
johng
Aug 13, 2001 10:33 PM
