Eg struts into an EF
Old Aug 20, 2005 | 07:41 AM
M15's Avatar
M15
Default Eg struts into an EF
Well my last car was a 94 civic coupe and i have the suspension from it and i wanted to know if i'm able to use the struts from that and just buy a set of coilovers for it. not sure if anyone has trie dthis but thouhgt it was worth a shot, if not then i have some more stuff for sale.
Old Aug 20, 2005 | 08:05 AM
kulangot's Avatar
Default Re: Eg struts into an EF (M15)
i have eg koni shocks on my 91 hf and the ride is great just alittle higher then when i had stock shocks on there...
Old Aug 20, 2005 | 02:32 PM
M15's Avatar
M15
Default Re: Eg struts into an EF (kulangot)
would there be any problem if i were to throw some coilovers on the Kyb's cause I wanna sit lower.
Old Aug 20, 2005 | 02:37 PM
kulangot's Avatar
if you go to low they can blow...but that's any shock..
Old Aug 20, 2005 | 02:43 PM
M15's Avatar
M15
Damn, well I'l lhave to give it a shot, if they blow out I'll let everyone know and they can laugh at me for being a dumb ricer and not buying all new stuff.
Old Aug 20, 2005 | 05:31 PM
DpSyChO's Avatar
Do you still have the EG front forks, you'll need them.
Old Aug 20, 2005 | 06:41 PM
Sikocivic's Avatar
Default Re: Eg struts into an EF (DpSyChO)
I have EG struts on my 90 Ef. I just used the EG forks and it fit just fine. The KYBs will handle the coilover, just keep the drop within reason.
Old Aug 20, 2005 | 06:46 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DpSyChO &raquo;</TD></TR><TR><TD CLASS="quote">Do you still have the EG front forks, you'll need them.</TD></TR></TABLE>
forgot about that....
Old Aug 20, 2005 | 06:49 PM
JDM Panda's Avatar
I just got my illuminas(which were supposed to be for my 91 crx ).. and they were for a eg.. they were way to long for my forks...
Old Aug 21, 2005 | 04:48 AM
DpSyChO's Avatar
Default Re: Eg struts into an EF (JDM Panda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Panda &raquo;</TD></TR><TR><TD CLASS="quote">I just got my illuminas(which were supposed to be for my 91 crx ).. and they were for a eg.. they were way to long for my forks...</TD></TR></TABLE>
Ummm....don't you mean too large diameter?
Old Aug 21, 2005 | 07:28 AM
JDM Panda's Avatar
no i mean to damn tall.. i didnt try to put them on the car there were about 5-6 inches taller than the stock 1's(5-6 cuz i was drunk, were only 1 1/2)
Modified by JDM Panda at 3:29 PM 8/21/2005
Old Aug 21, 2005 | 07:39 AM
d357r0y's Avatar
I have koni EG shocks on mine.. no problems.. they were roughly (within 1/2 inch) the same size as the EF shocks they replaced.
Old Aug 21, 2005 | 08:18 AM
Sikocivic's Avatar
Default Re: Eg struts into an EF (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">I have koni EG shocks on mine.. no problems.. they were roughly (within 1/2 inch) the same size as the EF shocks they replaced.</TD></TR></TABLE>
Mine where about 1/2-1 inch to long too but the EG forks are shorter, so they fit fine.
Old Aug 21, 2005 | 10:56 AM
M15's Avatar
M15
So as far as my drop what is 'within reason' , I wanted my rims to be right st the wheel well. i have 195/55/15 in. tires is this possible or will i need to go with EF suspension?
Old Aug 21, 2005 | 11:01 AM
turbotommy's Avatar
if you rocking a 55 size tire these will work. thats a mighty beefy sidewall. i also have swapped some tokico blues in my si. they were bigger than the oe crx struts. i didnt wanna use them becuase the damping characterictics change when you lower the car on eg struts. you have to drop 3-4" past what you would do on stock/aftermarket crx struts. and this my friend is alright kissing the bump stop
patrickstar
20
May 22, 2013 07:25 PM
rexracer626
Jun 11, 2010 11:31 AM
volksnuts
Suspension & Brakes
Jun 2, 2009 12:44 PM
UK_EG
Suspension & Brakes
Oct 4, 2005 03:05 PM
Lo-Buck EF
May 8, 2003 04:34 PM
