Makita LC1230
Old Aug 20, 2005 | 04:53 AM
RYSO's Avatar
Default Makita LC1230
Hi there,
Does anyone here have experience with the Makita LC 1230 cutoff tool?
http://www.toolmarts.com/mak_lc1230.html
Thanks.
Old Aug 20, 2005 | 05:55 AM
DaveF's Avatar
Default Re: Makita LC1230 (RYSO)
that seems really expensive for a chop saw.
i also recomend getting one that accepts a 14inch blade, since they seem to be more common.
Old Aug 20, 2005 | 07:02 AM
tony1's Avatar
Default Re: Makita LC1230 (Dturbocivic)
That one doesn't use a typical abrasive cut off blade, hence the price difference and different size wheel.
Old Aug 20, 2005 | 09:04 AM
Howitt's Avatar
Default Re: Makita LC1230 (tony1)
it uses a metal blade, they last a long time and make super clean cuts definetly worth the money
Old Aug 20, 2005 | 06:49 PM
RYSO's Avatar
Default Re: Makita LC1230 (Howitt)
It uses a metal blade that lasts ++ times longer than the regular abrasive blades.
A salesman told me that these models are only available with 12 inch blades.
Anyone with some experience with this machine??
Old Aug 20, 2005 | 08:06 PM
Bailhatch's Avatar
I have used a skillsaw type and it was amazing. Fast perfect cuts with little heat. I want the chop saw style bad!
Old Aug 20, 2005 | 08:39 PM
butch11a's Avatar
Default Re: Makita LC1230 (Bailhatch)
can you use that to cut sched 40 stainless, will the blade last?
Old Aug 22, 2005 | 08:05 PM
KFMRC's Avatar
Default Re: Makita LC1230 (butch11a)
Have had one for a few years now and the saw works great. Fast clean cuts on mild steel and c/m with the std. blade. Work must be clamped into the vise firmly and a steady feed will optimize blade life. I still keep my old abrasive makita around for doing thin tube headers though as I can just hold the tubing without clamping it. The material must be clamped with the 1230 . The 1230 has a much better vise setup on it than the abrasive saws do. Blades last a long time and can be resharpened but are not cheap.
Old Aug 23, 2005 | 12:57 PM
dfoxengr's Avatar
Default Re: Makita LC1230 (KFMRC)
i have both the HF bandsaw, with a new bimetal blade and cut-off saw, which i spent a total of <200$ on. and they both are awesome. i know you werent asking about those, but keep something like that in mind if you arent using it for a job or to make stuff a whole lot.
91akira
Detailing
Aug 5, 2009 06:03 PM
RJ#9
Welding / Fabrication
Jan 19, 2009 06:18 PM
Type X
Sep 17, 2006 07:30 PM
@irborne
14
Jan 29, 2006 09:53 PM
xdjoynerx
Aug 8, 2004 10:36 PM
